EcoModder.com
-   -   New undertray design (https://ecomodder.com/forum/showthread.php/new-undertray-design-12096.html)
AeroModder 01-31-2010 01:37 PM
After finally getting around to building my undertray, I got the two middle panels in. My biggest problem was space underneath the car, but I figured out a way to lift the jack higher.
Here are the two middle panels. you can see they're trimmed around the exhaust so it doesn't trap heat and/or fumes, or melt the coroplast.
http://i3.photobucket.com/albums/y93...Undertray2.jpg
Here's a picture of the front undertray I've had for a while.
http://i3.photobucket.com/albums/y93...tundertray.jpg
There was a definite reduction in wind noise, as well as a jump in economy. My estimate is a 5 MPG gain on the highway. My daily 40-mile commute used 2/3 as much fuel than before.
Photos of the rear panel of the undertray to come, when it's finished. I'm still working on the diffuser fins.
rav 01-31-2010 02:15 PM
Looks awesome, great job!!
AeroModder 01-31-2010 06:03 PM
Thanks!
Here's the final touches on the rear diffuser and undertray panels:
http://i3.photobucket.com/albums/y93...usercorner.jpg
http://i3.photobucket.com/albums/y93...ertrayrear.jpg
http://i3.photobucket.com/albums/y93.../Diffuser1.jpg
I left an inch of coroplast off of the end of the bumper so the airflow separates cleanly. I put another panel on the side to seal off the open area under the trunk, and made sure to fold some of the material up so it doesn't have a parachute affect. The other side is open, though, since I need to leave the muffler in open air.
moonmonkey 01-31-2010 06:33 PM
the rear verticle fins look like the ones one the fusion 999 flats racer, what specicly dop they do
AeroModder 01-31-2010 06:58 PM
They make sure the air moving through the diffuser stay straight and non-turbulent as the air pressure drops back to the ambient pressure.
Here's a thread from here on diffusers: http://ecomodder.com/forum/showthrea...read-8313.html
Cd 01-31-2010 07:51 PM
Nice
AeroModder 01-31-2010 10:11 PM
Now that I'm looking at it more.. I found out that the maximum angle of the diffuser is 25 degrees, which is far sharper than most. However, at slower speeds, I don't think this will make much of a difference. If I needed to, I could just add a few strips of coroplast between the diffuser and bumper as a spacer.
I could also put a smaller piece on the other side, but I'm concerned about the lack of mounting points on the open side. What do you guys think?
aerohead 02-01-2010 01:45 PM
2.5 vs 25
I believe that would be 2.5-degrees,not 25.The panel can go as steep as 4-degrees,depending on where it begins under the car.It's in Hucho's book.
AeroModder 02-01-2010 02:36 PM
The edge of the diffuser is 25 degrees from the horizontal.
I actually don't have Hucho's book, but I've heard it referenced quite a bit. Now, is there a certain angle-per-length requirement before the airflow detaches, such as no more than a 4 degree increase per foot of panel lenght?
Now I'm curious. *scurries off to do more research*
tasdrouille 02-01-2010 02:53 PM
Here's the figure from Hucho's book. Best angle is dependent on the aspect ratio of the diffuser (diffuser lenght/underbody lenght)
http://img72.imageshack.us/img72/4629/venturism8.jpg
