Newbe Ecomodder - Prius Owner
Well, my first mod was to block my lower grill on my '07 Pruis. I learned about this on Prius Chat. I just used the pipe insulation method. In order to maximize mileage I also reduced my speed on my commute from a max of 70mph to a max of 60mph. This has caused my mpg to jump from 46mpg up to 52+. My current tank is at 55mpg with just over 300miles on it. That has gotten me really excited. While I was happy with the 46mpg (in the northern california winters) I was shocked at the dramatic improvement I have achieved recently.
This has inspired me to install a more aerodynamic grill block. I am also considering lowering my car and or adding an air dam. I don't want my car to look too funky, but am willing to try a few mods. Then I found this site! I had no idea there was a whole forum devoted to mpg mods. I love it! I saw a design for a grill block made of coroplast that was put on a Honda Del Sol. I think I will try that first. Anyone know what kind of improvement I would get by lowering my car 20mm? (I can buy springs that would do that). What about adding 2" to my existing air dam? |
20mm? That's not very much of a drop at all, I would look for something more dramatic if you expect it to actually make any difference...but then I'm sure someone better on the aero aspects will chime in with better advice, ;)
Anyway, welcome to the site, don't forget to add a fuel log and garage, :) |
Welcome to the site. The Prius is a great car and very capable of big numbers. I think an airdam would only increase the drag thus decreasing FE. A block heater would do wonders to increase the FE. Check tire pressures, most here run pressure at max sidewall pressure or more.
What kind of commute do you have? |
Just curious, do you have a scanguage or anything to keep track of your water temp with your grill blocked. |
This is the grill block example I saw. I have not done it yet. My current grill block is for the lower only, using pipe insulation.
http://www.gassavers.org/showthread.php?t=701&page=2 My commute is from Danville, CA to Downtown Oakland, CA. About 25 miles each way. Highway 680 and 24. Mostly freeway. It includes one gradual incline up to a tunnel with an elevation difference of 1000 feet. The traffic is generally not too bad. I generally cruise in the slow lane at 60 like an old lady now. Although I am only loosing about 3 min per trip due to the 60mph speed. I have thought about getting a scan gauge, but have not splurged yet. |
Haha - that GS link shows the grille block on Dan's old Del Sol. Dan owns a Prius as well, and posts here once in a while (krousdb).
By the way, welcome to the site, Winston! If you're doing primarily highway commuting (and it sounds like you are), lowering the car will help very slightly. Lexus calculated a one inch drop reduced Cd on the LS400 (I believe) by .01. That may gain you (guesstimating) 1-2 mpg @ 60 mph. So, don't do it for the financial impact, though there may be other motivation. There are lots of mods you can do to a Prius in addition to these. And it's great to read someone's surprise at the savings from just slowing down. That's priceless! :thumbup: And just the beginning - the Prius responds particularly well to a motivated right foot. There's more fuel economy where that came from! |
Hmmm. That looks familiar......:p |
Dan! Do you hang around in the shadows waiting for people to mention your name so you can pounce?
That may be an old grill block, but it still looks great. I am wondering if he did the same thing for his Prius? |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
