Nice way to get aero shape.
Man Pours Strange Gunk All Over His Car. You Won't Believe What Happened Next... | SF Globe
This guy might not have made the most aerodynamic design but the possibility is there. I have some ideas for some things now anyway. |
It would actually work pretty good to make a kammback for a car.
You could pour into a cardboard mock up , so you get it basically right in the first pour. |
Foam-wrapping instead of bubble-wrapping!
Wicked. Nice find. It started out shaky, but had a nice finish. :)
thought I had seen this thread before!
Well, they claim the first thing to go is the mind, but I can't recall what was second...or third...or fourth...
I've see that Russian guy thing before, pretty amazing what determination can do with little resources.
The issue facing many of the weight sensitive home built hovercraft builders is the foam will absorb moisture right out of the air/atmosphere. You don't even need a pin hole leak, leave it out in the rain, or floating in the water for the weight gain due to air moisture content to show up. Maybe a car can deal with this weight gain better than a hovercraft. I do like that the foam is an energy absorber in case of accident though. |
Jethro made the aero back for his vw a few years ago.
http://veloliner.com/vw/IMAG0014.JPG |
Quoting myself from this thread:
http://buckminster.info/Pics/Icosahe...er_42'.jpg Frameless! |
