Old 07-02-2014, 08:19 PM   #1 (permalink)
CBR300R - '15 Honda CBR300R non-abs
90 day: 71.33 mpg (US)
Nice way to get aero shape.
Man Pours Strange Gunk All Over His Car. You Won't Believe What Happened Next... | SF Globe
This guy might not have made the most aerodynamic design but the possibility is there. I have some ideas for some things now anyway.
Old 07-02-2014, 09:19 PM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
It would actually work pretty good to make a kammback for a car.
You could pour into a cardboard mock up , so you get it basically right in the first pour.
Save gas
Old 07-02-2014, 10:15 PM   #3 (permalink)
...beats walking...
Foam-wrapping instead of bubble-wrapping!
Old 07-03-2014, 10:54 AM   #4 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Wicked. Nice find. It started out shaky, but had a nice finish.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 07-03-2014, 11:22 AM   #5 (permalink)
http://ecomodder.com/forum/showthrea...ing-28812.html
Old 07-03-2014, 11:42 AM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
thought I had seen this thread before!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-03-2014, 02:21 PM   #7 (permalink)
...beats walking...
Well, they claim the first thing to go is the mind, but I can't recall what was second...or third...or fourth...
The Following User Says Thank You to gone-ot For This Useful Post:
ecomodded (07-03-2014)
Old 07-03-2014, 02:30 PM   #8 (permalink)
I've see that Russian guy thing before, pretty amazing what determination can do with little resources.
The issue facing many of the weight sensitive home built hovercraft builders is the foam will absorb moisture right out of the air/atmosphere.
You don't even need a pin hole leak, leave it out in the rain, or floating in the water for the weight gain due to air moisture content to show up.
Maybe a car can deal with this weight gain better than a hovercraft.
I do like that the foam is an energy absorber in case of accident though.
Old 07-03-2014, 02:39 PM   #9 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Jethro made the aero back for his vw a few years ago.
Noah Webster, 1787
Old 07-03-2014, 06:20 PM   #10 (permalink)
Quoting myself from this thread:
Consider plywood for the ribs and cedar for the skin. A friend of my[sic] built a egg-shaped house on a Ford flatbed truck back in the 70s. He made plywood ribs, ran light wood stringers and shingled the whole thing. When it was done he had it sprayed out inside with polyurethane foam. What was a wobbly structure turned into a solid block of foam with the shingles embedded in the outer surface.
Where he shingled it vertically like a stationary house, you could turn the shingles 90° so they lay like fish scales.
Edit: He laborously hand tapered each shingle to fit. If I was suggesting it today (as I had then), I'd go for beveling each shingle[s thick edge], hot-melt gluing each one and using a geometry more like this:
Frameless!
