Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-15-2020, 02:19 AM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
When you are sweating passing the particulate test
Saw this several years ago and was reminded of it by a meme. Took me hours to track down the real thing.
Link to real thing: Drive The Change
Meme attached.
Old 12-15-2020, 08:40 PM   #2 (permalink)
That's a good meme. When it comes to aftermarket particulate filters, I remember around 2004 or 2005 there were some tests in urban transit buses in São Paulo (they were not mandatory in Brazil yet), and the trapped soot instead of being reduced was collected and used on rubber processing, and ultimately the rubber processed with that soot was used for retreading of the tyres fitted to the buses. Since factory-fitted DPF became usual in Brazil, with the regeneration in effect, it's not usual to recover the soot for industrial purposes anymore.
exhaust filter, smog sock, unicorn
