EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   No Connecting Rods! (https://ecomodder.com/forum/showthread.php/no-connecting-rods-38753.html)
freebeard 11-05-2020 04:22 PM
No Connecting Rods!
Opposed (Conjoined) piston engine with no connecting rods
I always liked the Scuderi Split Cycle engine but I thought it should be a boxer. What's popular with the cool kids these days in three cylinder/six piston opposed engines.
So maybe an opposed piston split cycle engine?
freebeard 11-05-2020 05:19 PM
Here is a four cylinder version. A flat eight?
Conjoined Piston Engine with Eccentric Connecting Rods
It appears the stroke is ~.68 the bore in this instantiation.
aerohead 11-06-2020 12:22 PM
no connecting rods
If they can achieve a BSFC of 0.135 lbs / bhp, and zero carbon, they'll win all the marbles.:)
M_a_t_t 11-06-2020 12:36 PM
Youtube also recommended this video to me. I thought it was interesting.
freebeard 11-06-2020 01:08 PM
Compare the Achates Power solution. Two crankshafts, one combustion chamber vs one crankshaft, two combustion chambers.
ksa8907 11-06-2020 02:53 PM
I do wonder how much friction or how quickly those gear mechanisms will wear. Seems like a lot of force with very little movement distance.
cRiPpLe_rOoStEr 11-06-2020 11:26 PM
Seems quite unpractical. Any increase to stroke would also be dependent on an increase to the bore too.
Even though the Achates Power design requires conrods and two crankshafts, it doesn't require a valvetrain which adds complexity. Not to mention the Achates Power doesn't require head gaskets, and the absence of actual cylinder heads is also claimed to decrease thermal losses.
freebeard 11-06-2020 11:33 PM
....the absence of actual cylinder heads is also claimed to decrease thermal losses.
Thanks. I think that's what I was looking for.
cRiPpLe_rOoStEr 11-06-2020 11:57 PM
Is it just me, or does anybody else sees some resemblance of its crankshaft with the one of a Wankel?
samwichse 11-08-2020 03:33 AM
Not sure why this is us in the unicorn gallery. I don't see any ridiculous claims being made, but it seems like a novel and compact arrangement.
