EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   No read , when I release the accelerator. (https://ecomodder.com/forum/showthread.php/no-read-when-i-release-accelerator-17597.html)
Colt200E 05-29-2011 06:29 PM
Hello, my car is
Dodge Colt 200E 1990, 1.5l, manual transmission, mitsubishi engine.
My problem is,
When I release completely the accelerator, the reading of inst. liter/100 turn to zero.At idle same thing.
And right away when I push on the accelerator the reading restart.
Someone had this problem??
Thanks
Colt200E 05-31-2011 12:26 PM
With a voltmeter, measure the voltage on each injector connection. One should be 12 volts and the other should be more like 0. You will want to tap into the one that is at 0 volts.
My 2 wire on injector connection have 12 volts???
Probably my trouble???
I Have one Hyundai Scoupe with the same engine 1.5 Mitsubishi, and Him also have 12volt on each wire.:confused:
CHECK MY VIDÉO FOR MORE:
http://imageshack.us/clip/my-videos/18/e1f.mp4/
mcmancuso 06-01-2011 03:55 PM
Thats normal, its called 'decel fuel cut off' the car cuts off gas COMPLETELY because the engine is slowing down and doesn't need to use fuel. Most fuel injected cars do this. It is not a problem. Then once RPM's reach a low threshold (varies car to car) the engine will begin using fuel again.
Colt200E 06-02-2011 03:01 PM
Oh my good it is a miracle, my car dont drink fuel... lol
My engine is 4g15 1990 and i dont believe he have the decel fuel cut off tecnologie.
Check this vidéo for the road test.
ImageShack® - Online Photo and Video Hosting
Thanks
Colt200E 01-04-2015 10:14 PM
Thanks
Update.
I install a wideband in my car, and my 25 year old car have this feature ''decel fuel cut off'' or ''overrun''.
