Old 12-25-2019, 04:47 PM   #1 (permalink)
Tire Valve Stem With Two Ends?
I know this is an odd request, but I have installed TPS caps on my tires, and I was wondering if there is a tee fitting that will allow me to fill, or bleed, the tires without removing the TPS cap. It would be so much easier to watch the TPS monitor as I fill, than to use a tire gauge with the caps off. I already know about the second valve stem idea, but I'd like to do this without drilling.
Old 12-25-2019, 05:17 PM   #2 (permalink)
OK, I found some online, but they stick out 2 inches.
