Oil Heater Blanket?
Hello -
This thread on engine heaters : http://ecomodder.com/forum/showthrea...deas-6040.html Made me want to ask about this : Pegasus - Heater Blanket, 2.5 x 20" - 200 watts, 120 volts http://www.pegasusautoracing.com/Images/L/3920.JPG Quote:
1 - $52 is an ok price for a heater (right?!?!?) 2 - Appears to be flexible for installation, you just need to have a 20" flat part of the oil pan to attach it to. Cons : 1 - Fragile. Easy to damage from overheating if it "disconnects/falls off" the oil pan. 2 - Easy to literally get burned from using it. At least that's my impression. CarloSW2 |
Wow, I was thinking about this very thing the other day....
I was also considering using the defroster heating elements from a dead refrigerator.... :D |
The eleproducts timer only works if you already have a car with a block heater installed.
How does the heater blanket stick to the oil pan? Does it have to sit on top of it, or do you make your own mounting setup for it? |
1 Attachment(s)
McTimson -
Pegasus - Self Bonding Silicone Tape, 1 inch x 36 ft roll http://www.pegasusautoracing.com/Images/M/3929.JPG Quote:
But, my problem may be that because I haven't seen how it is used, it may not be easy to install as I imagine. More hrmmmmmmmm ... It looks like it wouldn't work for where I would want to install it : http://ecomodder.com/forum/attachmen...2&d=1227058595 The exposed part of the oil pan does not have a 20" long flat section, which is what I think I would need. Sooooo, I think this would make more sense on a larger-displacement engine. CarloSW2 |
Carlos,
This is the product you are looking for. http://www.canadiantire.ca/browse/pr...08474396672419 They also make stick on ones that are more square, mine is and I think it would fit on your car. |
On an aside, I think heating the oil is better than heating the coolant because the coolant will come up to temp faster because the water jacket is clooser to the "fire" in the cylinder than the oil sump and the oil sump is attached to the block by a long thin piece of steel. I have a diesel and it shuts off the fuel when coasting in gear and there is a noticible bigger amount of engine braking when the engine is cold than when warm, even in the summer. That drag is pumping oil and really not much else. |
Duffman -
http://a116.g.akamai.net/7/116/8068/...9830801465.jpg Quote:
CarloSW2 |
I have one of those magnetic block heaters. one little detail is they say your suppose to take it off every time you use it. I was thinking about running a piece of wire around it to strap it down.
the engine heater stuff for an injected engine seems redundant for thier design..they are all delayed "up top" meaning they hang onto heat...gathers fast. If you have a carb engine,or small diesel, the heater is always a thought. the oil may never even warm up sometimes...
I spotted a 200w volt reducer from 120 to 12v(power invertor.) start the cold car, plug that in right away, and have something 200w heater related near the air intake, the engine takes care of itself after that...faster than the heater. The engine loses heat to its timing and design.. hence some may call some cars warm and other's not, even with the same engine and good heat system (no errors). I seek one for an old carb...I have the invertor, needs a wiff of warm beyond the hot choke to speed up frigid starts...simply.What to plug in... |
I had a block heater similar to this on my diesel smart car. It sticks on their REALLY well. Like.. Retardedly well. I noticed the smart would warm up much more quickly.
