EcoModder.com
-   -   Old Air dam= New Grill Block? What you think? (https://ecomodder.com/forum/showthread.php/old-air-dam-new-grill-block-what-you-10548.html)
RandomFact314 10-10-2009 04:19 PM
2 Attachment(s)
Hey my sister drives a jetta and her air dam was falling off multiple times (mostly because she cant drive and runs on curbs all the time) and She asked me to fix it again (it was hanging off one side) I told her I could fix it or just take the whole thing off and she told me to just take it off...
So then I got a air dam and I didn't really think about it until today but I could use it as a good grill block eh? light weight, durable, and big enough to cut to the size I need for my upper grill.
You opinions... I still have some foam core board, enough to re-make the grill block like 2 more times once mine goes bad from rain and stuff, should I just keep using that?
Also, the grill block is pretty scratched up, will that make the aero gain go bad?
Here are some pictures, the red squares are to show the random flat spots I could used to fit in my grill, the blue squares are ones that MIGHT fit...
http://ecomodder.com/forum/attachmen...1&d=1255205935 http://ecomodder.com/forum/attachmen...1&d=1255205935
RandomFact314 10-10-2009 04:25 PM
You could probably notice a lot of things about myself from these two pictures, haha, maybe I should clean my room a little B4 I take pictures to put online :)
Frank Lee 10-10-2009 04:26 PM
No, don't go there, the molecular alignments in the structure are all wrong and will lead to heartache and dismay. and worse fe.
Frank Lee 10-10-2009 04:28 PM
I don't see any underwear or porn so you're OK. :thumbup:
RandomFact314 10-10-2009 04:32 PM
3 pairs of boxers in the first picture but not very noticable so I'm still in the green :p
RandomFact314 10-10-2009 04:34 PM
I figured once I cut out the square I would try to fatten it out as much as possible with heat and some flat pressure :confused: still bad idea ya think?
MadisonMPG 10-10-2009 04:35 PM
I spy sketchers, which are a nono.
RandomFact314 10-10-2009 04:37 PM
I wear Vans, the sketchers were shoes I wore 1 time for graduation, I have tons of old papers in that box. :thumbup:
RandomFact314 10-10-2009 09:41 PM
So does no one have a thumbs up or thumbs down for this idea? Just one person?
Frank Lee 10-10-2009 10:17 PM
Aren't my answers all anyone could ever want?
