EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Old school original VW Beetle aeromods: "Herrod Helper" rear spoiler (https://ecomodder.com/forum/showthread.php/old-school-original-vw-beetle-aeromods-herrod-helper-7444.html)
MetroMPG 03-11-2009 09:44 PM
2 Attachment(s)
Every once in a while, Phil (aerohead) spits out some interesting aero factoid in passing in a thread that sends me out into the internets, searching for more info. This is another example of that.
We've all seen Ernie Roger's New Beetle bug wing:
http://max-mpg.com/images/image007.jpg
Ernie calculated it improved his drag coefficient from .38 to .28 and fuel economy by 5-8%, depending on speed.
I forget which thread it was that Phil said something like, "yeah, old news. VW's had aftermarket drag reducing spoilers back in the day" (paraphrasing). (Not diminishing Ernie's efforts, just pointing out that others were trying to "correct" the Beetle shape in the past.)
"Herrod Helper"
From: TheSamba.com :: VW Dictionary and TheSamba.com :: View topic - Herrod Helper
http://ecomodder.com/forum/attachmen...1&d=1236821838
http://www.thesamba.com/vw/archives/...rodhelper2.jpg
Apparently, it was originally sold through JC Whitney, and mail order, and for $12.95, promised:
  • better mpg
  • greater top speed
  • reduced noise
  • better handling
  • "releases that 300 foot column of vacuum you are now towing around"
  • a "racy look" :)
http://ecomodder.com/forum/attachmen...1&d=1236821900
The only thing I couldn't figure out was why they called it "Herrod Helper".
MetroMPG 03-11-2009 09:47 PM
Oh, found the thread where Phil referred to this spoiler: http://ecomodder.com/forum/showthrea...lips-2685.html
aerohead 03-12-2009 07:13 PM
Herrod
Darin,I can only guess, that a fella by that name came up with it.That's really fun that you could track down the ad.The internet's amazing!
Big Dave 03-12-2009 09:50 PM
The ad says: "...guaranteed to outlast your Beetle."
alohaspirit 03-13-2009 01:22 AM
wheres the ecomodder thread for that new beetle wing?
Frank Lee 03-25-2009 10:26 AM
This month's Hot VWs' "Project Mileage Motor Part 17" series "tests" the Herrod Helper.
MetroMPG 03-25-2009 10:56 AM
I take it (from the quotes) you're not confident in their "test" methodology?
Frank Lee 03-25-2009 10:58 AM
They run a test loop out on the road, usually once but in this case twice, then report to two decimal places. Way too small of a sample for making claims. No A-B-A either.
Still, they are brushing 40 mpg without special driving techniques it seems.
rmay635703 03-25-2009 11:13 AM
I wonder if that would help my Subaru 360, which is nothing more than a fancy small VW bug except I have a grille accross the back side of the car
My Subaru pushes 40mpg in town at 15 degrees with a fuel leak and exhaust leak. Perhaps I can do better with this thing
aerohead 03-26-2009 04:22 PM
Subaru 360
rmay,is that the tiny car I could lift the front end off the ground in the 1960s?
