One very smart LED, Battery monitoring like you've never seen it before
AutoSpeed - One very smart LED
http://i110.photobucket.com/albums/n...ps3vmzp7j6.jpg http://i110.photobucket.com/albums/n...ps34kkrsra.jpg In fact, here is a battery monitoring LED that is user-programmable to run one of six different in-built maps. The single LED can show green, red, yellow and white, can also flash at different rates. The voltage is monitored as a rolling average over 2 seconds, is claimed to be accurate to 1 per cent, and will operate over 3.8 – 30V. Map 1: Battery Voltage Monitor Map 2: Vehicle Charge Indicator Map 3: Vehicle Monitor , includes fake alarm Map 4: Charge Indicator (Stealth Mode) Map 5: High Res 10 step voltage monitor Map 6: Minimal Monitor The maps settings (the second lot of flashes) are as follows: Map 1 – red flashes Map 2 – green flashes Map 3 – yellow flashes Map 4 – red and then green flashes Map 5 – yellow and then red flashes Map 6 – yellow and then red flashes search Gammatronix on ebay, between 20-30.00. |
Trouble is I would need anywhere from 16 - 48 of those things to be a usefull BMS.
I like to have more precision and prefer a digital readout instead of colors to indicate ranges. For that reason, I have one of these
LED Car Battery Electric Cigarette Lighter Voltmeter Voltage Meter Gauge Tester | eBay The downside is that it consumes 40mA and can drain a battery if left in a plug that maintains power after the vehicle is turned off. |
