AutoSpeed - One very smart LED
In fact, here is a battery monitoring LED that is user-programmable to run one of six different in-built maps. The single LED can show green, red, yellow and white, can also flash at different rates. The voltage is monitored as a rolling average over 2 seconds, is claimed to be accurate to 1 per cent, and will operate over 3.8 – 30V.
Map 1: Battery Voltage Monitor
Map 2: Vehicle Charge Indicator
Map 3: Vehicle Monitor , includes fake alarm
Map 4: Charge Indicator (Stealth Mode)
Map 5: High Res 10 step voltage monitor
Map 6: Minimal Monitor
The maps settings (the second lot of flashes) are as follows:
Map 1 – red flashes
Map 2 – green flashes
Map 3 – yellow flashes
Map 4 – red and then green flashes
Map 5 – yellow and then red flashes
Map 6 – yellow and then red flashes
search Gammatronix on ebay, between 20-30.00.
