Old 09-09-2009, 04:55 PM   #1 (permalink)
Tyre pressure monitor system
Just found this system for sale in the UK, it comes with 4 wireless sensors, 4 alloy valves, the main unit and power adaptor.
Tyresure 4 Wheel Car and Small Van - £179.00 : Ecotune Sussex, fuel saving, wheels and tyres
They say to contact them if delivery is to be outside of the UK.
Just thought it might be of use to somebody, Measures up to 60PSI too..
Old 01-21-2011, 03:14 AM   #2 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Tire Pressure Alert Valve cap - Tire Pressure Alert valve cap
Have anyone tried these? They promise 3 weeks battery life, when blinking? Works with pressures up to 120 psi
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 01-21-2011, 11:36 AM   #3 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I don't see any details on this. Is it possible to set the alert pressure? And does installation promote slow tire leakdowns like a previous products I tried?
It would be pretty useless if you can't set the alert pressure to something useful for folks who run pressures over 30 psi...
Old 01-21-2011, 01:36 PM   #4 (permalink)
The PRC.
On the link in the first post I'm seeing an ad for adult movies, just in case someone clicks on it. The ones after that seem fine.
Old 01-21-2011, 03:23 PM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
A few years back I bought some tire pressure valve caps from Napa Auto parts that changed color when the pressure dropped by more then 4psi, they looked alot like these and measure PSI of 26, 28, 30, 32, 34, 36, 38, 40, 45, 50, 55, 60, 65, 70, 75, 80, 85, 90, 95, 100, 105, 110, 115 and 120
The ones I had were of another brand but I never had issues with them, they were 50PSI and warned me a number of times of slow leaks that I then repaired.
pressure, tires, tyre
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Hello from Texas spil Introductions 2 09-03-2008 06:38 PM
