EcoModder.com
-   -   Oops, I did it again! Bought another cheap, 3-cylinder Mirage. Mods in progress... (https://ecomodder.com/forum/showthread.php/oops-i-did-again-bought-another-cheap-3-a-38447.html)
MetroMPG 06-21-2020 07:25 PM
4 Attachment(s)
I just bought another cheap "AS-IS SPECIAL" Mirage. Like my previous one, this was traded in at a new car dealership that wanted nothing to do with it:
https://ecomodder.com/forum/attachme...1&d=1627568512
Also like the last one, it's a 2014 top trim 5-speed. But even fancier! Factory body kit! Rain deflectors! All the chromed plastic bling you can stick on it! Talk about gilding the lily.
147,000 km = 91k miles - a bit high for the year.
It looks like it may not need any repairs to pass inspection (mandatory in Ontario). OK, the summer tires are shot, but it came with a set of winter tires on wheels with plenty of meat on them which will pass muster. Considering this will be my next winter beater, that's fine with me.
And it came slightly pre-ecomodded:
https://ecomodder.com/forum/attachme...1&d=1592780492
1) Factory block heater
It's one of the cartridge style ones that slips into an existing hole in the engine block. 450 watts, I believe.
https://ecomodder.com/forum/attachme...1&d=1592780574
2) Aftermarket Boat Tail Attachment Point!
I probably won't keep this car past next spring, so a tail may not appear on this exact one.
But I will be keeping the hitch and the block heater for when I eventually get my "forever Mirage".
Non-ecomods:
A) I already removed the rain deflectors.
B) Unfortunately, the previous owner replaced the factory 165 width LRR Dunlop Enasaves with non-LRR 175's. The car doesn't roll as well as my first one.
In stock ecomods awaiting installation
Of course I saved all the coroplast bits & bobs from Mirage #1...
https://ecomodder.com/forum/attachme...1&d=1592781253
Just a matter of installation.
From Thread: I just bought Canada's cheapest 3-cylinder Mitsubishi Mirage. EcoMods now in progress...
Ecky 06-21-2020 07:49 PM
Nice find! What're you looking for in the Forever Mirage?
MetroMPG 06-21-2020 08:03 PM
Honestly, I'd prefer the base model car. Just say no to Cadillac Mirages! The base model is lighter, has fewer gadgets, wind-up front windows, no AC (in Canada).
I think the only thing I'd really miss on the upper trim is cruise control, but it's not super hard to install switches and enable the feature in the car's computer.
MetroMPG 06-23-2020 01:41 PM
Only one surprise
1 Attachment(s)
Well, I've gone over the car, and I don't think it needs ANY repairs to pass inspection. That's exceedingly rare for the kinds of cars I tend to buy!
I was honestly expecting the front brakes to be trashed (rusted) after sitting for almost a year outside, un-used, at the car dealership. The outer rim of the rotor was definitely crusty, but I went at them with a file & wire wheel and they cleaned up reasonably well. Lots of meat left on the pads, and the calipers & slidey pins are all good too.
This is the worst thing wrong with the car:
https://ecomodder.com/forum/attachme...1&d=1592933409
Driver's side floor mat is trashed! Left heel hole? I've never seen that before. (Neither has Mitsubishi, or they would have made the heavy-duty portion a bit wider!)
The cheap, thin, mouse fur carpeting is worn off the dead pedal area too.
samwichse 06-23-2020 02:58 PM
Ewwww someone was riding the clutch on that car.
MetroMPG 06-23-2020 04:34 PM
You would think so!
But the clutch is actually in great shape - it's better than Mirage #1's.
And the clutch pedal pad isn't worn. But there IS corresponding heavy wear on the dead pedal, so I think it's just a weird way they rested their left foot.
Oh.... another thought: high heels??
Fat Charlie 06-23-2020 08:55 PM
I've only seen one floormat ground through. The customer denied ever wearing high heels. My boss suspected horseshoes.
Gasoline Fumes 06-24-2020 01:26 AM
1 Attachment(s)
https://ecomodder.com/forum/attachme...1&d=1592976331
jakobnev 06-24-2020 03:27 AM
Big feet, small car: the previous owner was either a clown or a porn star.
MetroMPG 06-24-2020 08:51 AM
I like Fumes' conclusion: I'm going with cowboy! :D
cRiPpLe_rOoStEr 06-24-2020 06:23 PM
Reminded me of the days when most Argentinian subcompact cars usually had manual windows when fitted with AC, even though power windows were more sought after on cars without AC.
MetroMPG 06-24-2020 08:25 PM
^ That makes sense, actually.
The Canadian base model (no AC) is even slightly more strange and/or logical: it has power REAR windows, but hand-crank front windows.
cRiPpLe_rOoStEr 06-25-2020 03:40 PM
The opposite of what I usually see in Brazilian cars nowadays.
samwichse 06-25-2020 04:32 PM
Now that I think about it, it's probably because the power windows have a lockout for the driver. I bet it's a child safety regulation.
MetroMPG 06-25-2020 07:13 PM
Not a regulation, but that's a good reason I hadn't considered!
Fat Charlie 06-25-2020 08:26 PM
If you want all the windows open, you can. That's reason enough.
mpg_numbers_guy 06-26-2020 12:49 PM
I have been out of the loop for a while! Saw this thread and I was like, whaaat? MetroMPG's starting to hoard Mirages? before I realized that you had sold the silver one.
MetroMPG 06-26-2020 01:09 PM
It's just a matter of time, I'm afraid.
Fat Charlie 06-26-2020 08:56 PM
At least you're in a self-help group for it.
cRiPpLe_rOoStEr 06-27-2020 01:38 AM
Had it been for childproofing, I guess hand-crank windows would have been explicitly banned. On a sidenote, when some cars which used to feature power windows on the 4 doors started to feature it only on the front doors, this became a matter of concern for parents who resorted to it as a child safety measure.
cr45 06-27-2020 11:12 AM
I have a 2014 UK base 1.2 manual Mirage, the 0.27 CD model.
It has the following features
1/ Steel wheels - 165/65-14
2/ No AC
3/ Electric Windows front and rear.
4/ Radio speakers front and rear
5/ Tinted rear windows
6/ Rear window wiper
The most basic Mirage that was ever sold in the UK for a few years was a version of the 1.0 which had no rear electric windows, no rear speakers and no rear tinted glass. I seem to recall that it had no rev counter.
I must say that I like having the tinted rear glass as it gives a certain amount of privacy.
cRiPpLe_rOoStEr 07-02-2020 05:56 PM
Originally Posted by cr45 (Post 627094)
Rear window wiper
Nowadays I don't see modern hatchbacks without rear window wiper in Brazil, the last one I remember seeing was a 1st-generation Chevrolet Onix but it was an export version for Argentina. Sedans on the other hand, to which rear wipers are most frequently found on JDM models, I remember some didn't have a rear window defroster when fitted with air conditioning and export-bound.
Besides some Toyota and Ford hybrids, I haven't seen any car or SUV newer than 2014 without a rev counter in Brazil.
MetroMPG 07-06-2020 06:39 PM
2/ No AC
That sounds very similar to the base model Canadian Mirage, which is the one I'm ultimately going to get. Except ours had power rear windows only, crank front.
MetroMPG 07-06-2020 06:43 PM
First fill 63 MPG US
1 Attachment(s)
63 MPG US = 3.7 L/100 km
That's calculated at the pump (3 clicks) over 566 km / 352 miles.
Interestingly, for the first time ever, a car's factory economy gauge was slightly pessimistic (showing 3.8) vs. the calcs!
I'm quite happy with that, considering I only starting adding ecomods to the car part-way through this tank. And I did hardly any engine-off coasting. Most of that driving is highway (80 km/h = 50 mph max limit) on cruise control, tapping up & down for hills, traffic permitting.
On top of all that, it included a ~120 km trip like this:
https://ecomodder.com/forum/attachme...1&d=1594075380
MetroMPG 07-20-2020 01:44 PM
spurs
1 Attachment(s)
Originally Posted by Gasoline Fumes (Post 626827)
Solved!
https://ecomodder.com/forum/attachme...1&d=1595266961
$20 for a set of floor mats, almost brand new!
Sadly for the seller, they wrote off their Mirage just after switching over to winter mats/tires. (They were selling 15" alloys with almost new factory tires, but not the LRR ones I want.)
MetroMPG 07-20-2020 01:56 PM
65 MPG tank?
1 Attachment(s)
I filled up Mirage #2 @ 719 km / 447 miles and it came out to 64.5 MPG US = 3.68 L/100 km.
Can we call it 65? https://mirageforum.com/forum/images...es/biggrin.png
That may be the high-water mark for this year; probably the last warm weather tank that won't include at some highway driving with the kayak sticking out the hatchback, which wrecks aero. Seems to be a 5-10% MPG hit.
But I did figure out how to remove the factory drag-reducing spoiler for future trips, because it actually makes aero worse when the hatchback is half-way open vs. none at all.
https://ecomodder.com/forum/attachme...1&d=1595267800
Daox 07-20-2020 03:53 PM
How big of a pain was it to remove? Any double sided tape?
Fat Charlie 07-20-2020 08:51 PM
You're the only guy I know who complains that a boattail reduces his mileage.
MetroMPG 07-24-2020 10:05 AM
Boattail: good idea, bad execution! :D
Daox: yeah, there was some super sticky trim tape under the outermost 2 bolts. I used the old "saw through it with dental floss" trick.
There were also 4 small, flimsy clips which I broke during removal. (Not a problem - I think they're just there for assembly alignment.)
MetroMPG 08-13-2020 04:32 PM
Winter awaits
I parked the Mirage yesterday (and started driving the MPGiata). Next time I use it again will be for winter duty sometime in late Oct or early Nov.
For how cheap these cars are now, I'm impressed.
Daox just knocked out an 83 MPG US segment over 17 miles in his. I haven't tried any hardcore P&G in mine yet.
I am seriously considering what I should do with my 2 Fireflies and 1 Metro.
cRiPpLe_rOoStEr 08-14-2020 01:06 AM
Not sure how hard the downturn caused by the Chinese virus hit Canadian economy, but anyway, in times like these it would be supposed to push people from gas-guzzlers to something more affordable to run, just like the 2008 recession did for older subcompacts such as the Ford Festiva and the Suzuki Swift.
Fat Charlie 08-14-2020 06:09 AM
You'd also think a contagious, deadly respiratory disease would push people to wear face masks.
This is a different kind of recession, normal economic realities and motivations for recessions don't apply well here.
Piotrsko 08-14-2020 09:56 AM
Don't forget gas is relatively cheap
MetroMPG 08-14-2020 10:51 AM
Mirage sales are down significantly. (This yr.)
Pickup truck sales continue to dominate.
If I had to bet, I'd say there won't be a 7th gen Mirage coming to North America. We'll get a refreshed fascia (2nd refresh, 3rd "face") on the car for the 2021 model year, at which point the platform will be in its 9th year. Mitsu may stretch it to 10 years of production as they did with the Lancer.
So if the last Mirage is sold in Canada in 2021 or 2022, that means I can reasonably expect to still find decent used ones for sale in the 2030-2035 timeframe. :D
cRiPpLe_rOoStEr 08-14-2020 05:07 PM
Either this, or they turn it into another SUV, attempting to replace both sedan and hatchback with a single bodystyle. Maybe this could also mean the Mirage would finally come to Brazil, as the local branch of Mitsubishi focuses only on SUVs and the L200.
MetroMPG 02-23-2021 12:59 PM
Worst Mirage fill so far
52 MPG on my latest fill (also the longest I've gone between fills in many years):
https://ecomodder.com/forum/fe-graphs/graph10742.gif
Could it be the winter grade fuel? Is it due to winter weather conditions? Am I getting lazy in my old age and putting less effort into eco-driving? Am I using cruise control instead of driving with load? Did I use the car for some shorter trips that I might have biked otherwise?
Yes.
For comparison, here's the previous Mirage's fuel log - much better winter numbers:
https://ecomodder.com/forum/fe-graphs/graph10645.gif
Gasoline Fumes 02-23-2021 06:48 PM
Maybe you should use days per gallon.
cRiPpLe_rOoStEr 02-25-2021 10:14 PM
I would not be surprised if those factors are more relevant to the decreased fuel savings than winter grade fuel.
MetroMPG 03-23-2021 10:09 AM
Larger diameter tires for better gearing
1 Attachment(s)
https://ecomodder.com/forum/attachme...1&d=1616507521
With winter gone, I'm thinking of trying these old 15" Civic wheels that I have in my junk pile. Civic tires are 185/65/15, where the Mirage stock size is 165/65/14.
I plugged the tire numbers into this tool: https://www.blocklayer.com/tire-size-calculator.aspx
And it tells me that change would reduce engine RPM (in all gears) by ~8%.
At 80 km/h (~50 mph), the engine is turning around 2250 RPM on the stock tires. Those Civic wheels & tires would drop it to ~2070 rippems!
The final drive swap I did to my Firefly dropped cruising RPM by 20% and increased steady state cruising fuel economy by about 5%.
So all else being equal (it's not), this might net around 2% better MPG's.
Assuming I remember to adjust speed because the speedometer will be off (reading lower). https://mirageforum.com/forum/images/smilies/smile.png
Pontential downsides that might cancel the gearing change:
A: They're heavier.
B: Multiple aero penalties: extra width, plus they'll raise the ride height a bit.
Ecky 03-23-2021 10:18 AM
Heavier and wider tires impact (stock) Insights pretty significantly, but I'm interested to see what comes of this on your Mirage.
