Overheating problem.
I'm going to make a dedicated overheating thread as I need help. I don't know what to do at this point.
Things I have tried: Coolant flush. Thermostat replacement. Block test (came up fine). I'm out of ideas. The coolant flush made my situation worse. I use to be able to put around town all day with no problems at all, and now just going to my friends house, which I have done a dozen times in the insight, it overheated. |
Who did the block test? Sometime they wont show up and then all of the sudden it shows up bad. I had a cobra like that.
Did you bleed the cooling system after the flush-thermostat? I posted in the other thread I thought it was the radiator. A radiator shop can test it for hot spots in the radiator.
regards mech |
My radiator was full of dirt and road dust, kept overheating on hill climbs. Try getting a car wash spray up close. Oh yeah I had tried everything also... I felt SO stupid!
new radiator
Does the heater work? If it doesn't its the water pump. Is the fan coming on? If the top hose from the radiator is hot you can know the thermostat is good.
This is the one I got, on a bid for 55.99, however you will need a different one for the insight.
I should take a photo of the old one before tossing it in the trash. |
Omg I think that's the problem /facepalm. The previous owner told me that he left it on a hill and forgot to put the e-brake on, the car got away from him and ended up at the bottom of the hill against a telephone pole... Just... Look at the pics below /facedesk 100x.
http://imageshack.com/a/img673/7935/LlAo5e.jpg http://imageshack.com/a/img537/8498/i4ZCJP.jpg http://imageshack.com/a/img537/9613/xXMCCh.jpg |
What's going on in the second pic? Kinda looks like a damaged induced, lower condenser block situation
Also any time you open up the cooling system there is a very specific bleeding procedure. regards mech |
Here is a youtube video of the bleeding procedure.
http://www.youtube.com/watch?v=dy20RzJ4sQg regards mech |
Don't confuse a proper bleeding procedure with a bad radiator diagnosis. They are not related. You can put a brand new radiator in the car and not bleed it properly and it will still overheat.
Keep opening the bleeder until you get nothing but liquid coolant, That COULD fix the problem. The dealership replaced the water pump bypass hose on my Riviera. It was running hot until I took it back and they bled it until it had no air pocket and it ran cool. regards mech |
The first night I got the insight, I took it up the same hill and it stayed at 206.6 the entire time. This run, stayed dead at 203, and with that being said, it was hotter tonight then the night I tested it. Tomorrow when I go to my friends house we will see how it does. It's supposed to be hotter tomorrow then today. |
Check the coolant reservoir cap. The system is pressurized and a bad cap can cause the symptoms you are seeing. Not likely, but one more thing to check. I had a problem with a car I couldn't get to cool after a minor front end collision. Burped the hell out of it, new thermostat, cleaned it. finally replaced the radiator and it worked great. 150k miles on it and I think the "bump" dislodged some crud or damaged it internally.
Is 206 over heating? I dont know about my cts, but my old intrepid wouldn't even flip the fans on until 215 iirc.
I don't think it will suck air, but you dont want to get BURNED. Wait until it is down to warm after maybe 15 min and slowly release. It should still be able to hear the pressure release.
Maybe someone with more experience than I can comment |
I think OEM for the 00 insight is 172 to 192, about the same as the civic, so I think 206 is too hot for just starting to drive. What temp does the fan come on? It comes on at 206 on the civic.
Also, you guys have to remember the ambient temp out here is 99-104. |
To know you have the system bled properly.
Engine cold. Fill the radiator to the top and the recovery bottle to the middle between the hot and cold marks. Run the engine until it gets hot, then bleed with the cap on and tight. Repeat this process until you get no more air out of the bleeder. The level in the recovery bottle will go up as the engine gets hot, but what is most important is the level in the recovery bottle should GO DOWN as the engine cools. When there is an air pocket in the system the coolant level in the bottle will not go down as the engine cools, because the air pocket is preventing the cooling system from pulling coolant from the bottle as the coolant cools off and the coolant contracts. If there is any doubt, bleed again, as I said earlier, until you get no more air. Then, if you still experience overheating, the radiator is your problem. To confirm this, you will have little difference in top and bottom hose temperatures, which means the radiator can not remove enough heat from the coolant to keep the car cool. When the system is working properly, with normal capacity in the radiator, it should stay in the normal operating range even in ambient temperatures 20 degrees higher that you have locally. The additional capacity is designed in the system and you don't read about manufacturers denying warranty claims in Phoenix Arizona or telling buyers they can expect their engines to melt. regards mech regards mech |
Also, once again, thank you for your help. If you wanna call me and explain this to me instead of trying to type it lemme know haha. |
Absolutely not. Cap must be on and tight before you start the engine. That pressurizes the system, as it warms up, to help the bleeding get the air pocket out. It will NOT work if you leave the cap off and as the coolant heats up it will overflow with the cap open.
regards mech |
Never let the recovery bottle level get below the minimum or it will suck air into the engine when it cools off and you get to start the process, from scratch, all over again.
Run the heater on max heat to make sure their are no air pockets in the heater core during warm up. When you can not get any more air out of the bleeder you are done. It could take several cold-hot cycles before you get no air and I like to check it after a while to make sure I got all of the air out. regards mech |
Oh also, I'm going to check both the radiator hoses to make sure one isn't hotter then the other. |
Bleed when you get home, then let it cool and top off again. Never run it with the cap off unless you are checking for proper thermostat operation and opening temperature, which you have already done when you replaced the thermostat. regards mech |
And 90% of the time on my way home from work the past, 3 weeks I have used the heater, it gets down in the 50's at night (that's cold, for me at least). I will burp it when I get home though before I go to bed. |
Use the heater, it helps to get any air circulated out of the system. The absolute best way to get it completely bled is to drive the car on your commute and use the commute to avoid running the engine unnecessarily.
The recovery bottle cares not about a 4% slope. Check to see that the coolant is filling the recovery bottle when you stop with the engine hot, at your destination The bottle usually has a cold and hot mark. As long as you check it consistently cold and hot you know the level and if it has changed through several cycles (cold-warm). When the changes are exactly the same and you can't get any more air out of the bleeder, youre finished with bleeding. If you open up the system, anywhere except at the cap when cold, you get to start the bleeding process all over again. regards mech |
You do not need to remove anything to check the recovery bottle or to bleed the system, except to open the bleeder. Only open things when the engine is cold or you could get burned badly by scalding hot water, a real danger when you have a big air pocket that gets super hot then gets hit with colder water and you have a geyser of scalding water blowing out of the radiator and all over you.
YOU WILL ONLY DO THAT ONCE! I have'nt regards mech |
Forgot to add, car did not overheat on way home from work. |
It means you should keep bleeding it until it has no air. I would call the hot top and luke warm bottom hose working right, but KEEP BLEEDING. I could hold my hand about 5 seconds on 185 degrees. I think yours is around 200, which is fine if that was what it called for and you should not see it go beyond 225 (thats a guess). Make sure your coolant is 50/50 not more or less (helps heat transfer).
Now if you climb a steep grade like before what does it read? That's a stress test and it will probably go higher than other times. When that reading (after climbing a steep grade) causes the temp to skyrocket but there is no air bubble and the cooling system operates normally otherwise, you need a radiator. regards mech |
