A paper on aft-end underbody diffusers
I have found a few threads here about projects for making underbody diffusers. Here is a dissertation I found that may be of interest to some ecomodders:
"An experimental study of automotive underbody diffusers", by Lydia Jowsey, 2013. It was a bluff-body wind tunnel study that included variables of diffuser angle, number of channels and ride height. The material is quite interesting. Link: https://dspace.lboro.ac.uk/dspace-js...013-Jowsey.pdf At the end are appendices with data tables from full scale tests done in 2009 of a Ford Focus and a Ford Modeo hatchback. Unfortunately, the Focus model was not mentioned (sedan?, hatchback?), and these tables are not discussed anywhere in the document. Cd is provided and is of interest, but much that is in the tables is cryptic. Maybe someone else can make heads or tails out of them, particularly what led to the minimum Cd figures. |
"Submitted in partial fulfilment of the requirements for the award of
Doctor of Philosophy of Loughborough University 2013" Philosophy?? Quote:
Can anybody translate this into simple terms? |
I skimmed it and the salient point was provided by wdb above. Drag was not the target, maximum downforce was. No need to read into that further as downforce is a real drag :P
But if you read it more carefully, drag is discussed quite a bit and it is covered in several of the charts. Also, it is covered in all the rows of the tables in appendixes A & B.
Will be reading the article later Focus-AK, thanks for the link. |
But that's not really important. The important question that we should answer is what is the best angle for US. |
paper
Without wheels,the model seems way too simplistic to dovetail any results into real world expectations.
The presence of wheels can alter the drag by 2X and their addition to the model would significantly affect performance of the diffuser(s). The info on the Focus car would have been more useful. |
Here is a sjmilar degree from UKansas: Doctor of Philosophy in Aerospace Engineering: Degree Requirements - KU Catalog James |
Dr. Jowsey's Phd is in automotive engineering (an applied science). And of course, since things mushrooms, there are now PhDs in music, sports, etc. |
