Old 12-21-2009, 09:57 PM   #1 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
are boat tails for hatchbacks & sedans?
I have a 2002 2 door echo sedan, i have done a partial grill block and am going to do rear wheel skirts and belly pan, i saw wind tunnel pictures for a hatch and a sedan , the sedan had less than half the turbulance/drag at the rear of the car, how much benifit is in aero modding my echo rear, and what shape ,,,like the aero civic? the ford fusion hydrogen 999 speed record car has a funny car style rearwing on it. does that work cause it looks alot better than a boat tail.
Old 12-21-2009, 10:46 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
That Ford: 2007 Ford Fusion Hydrogen 999 Land Speed Record - Ford Fusion Hydrogen 999 Marks Milestone 6 - 1280x960 - Wallpaper
Aero is too tricky for definitive answers to your question, but you can get a better sense of the possibilities by reading this site.
Old 12-21-2009, 11:03 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
moonmonkey -
Here's a little text from the same site to go with Bob's URL (but no aero stuff mentioned) :
2008 Ford Fusion Hydrogen 999 Land Speed Record
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Cd (12-22-2009)
Old 12-22-2009, 01:14 AM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Moonmonkey - Boattails have been added to sedans, for example wagonman76's 4-door Celebrity iirc.
But before you go there try a few other mods, like rear wheel skirts and a full bellypan, both of which improve the airflow on the 'tail if and when you decide to add it.
You may also try a partial roof extension without sacrificing functionality, as in Groar's Uglyback.
Old 12-22-2009, 08:55 AM   #5 (permalink)
...beats walking...
...someone needs to "point" him to that aero article where the typically aero "drag" losses were summarized. That should give him some idea as to how much "gain" is possible with various modifications.
...anybody recall that article?
Old 12-23-2009, 12:47 PM   #6 (permalink)
funny car
I have VHS video of a car with the funny car style extension running flat out at El Mirage Dry Lake,California during a pre-Speed Week warm up with SCTA.
Anyway,El Mirage is reaaaaaaaaaaaaaaal dirty,and you can see the entire wake exposed by the dust.
The area above the spoiler is completely clear,indicating attached flow( if not over a locked-vortex ) and complete "dirt" below and behind indicating that the wake is isolated to the area below and aft of the panel.
Short of a tail,this would definitely be one way to go.
You might shoot for a 15-degree angle from rear edge of spoiler up to top of roof over the backlight and trunk.
When GM set the land speed record with EV-1 their boat tail tailcone created a 15-degree angle,so it appears to be a good compromise angle.
One caveat,would be to "soften" the rear edge with rubber so as not lacerate some un-suspecting mindless automaton,wandering aimlessly by muttering incantations.
Cogito,ergo imodifi!
Old 12-23-2009, 08:41 PM   #7 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
See Attched Image: Appears that the Fusion is about a 12 degree angle when looked at from this perspective. Aerohead, is this the correct way to use a deck lid spoiler to achieve this locked-vortex you are talking about?
Name:	Fusion Angle.JPG
Boat dremd General Efficiency Discussion 14 07-25-2012 08:51 PM
Boat Tails; Even NASA uses them! bzillins8806 Aerodynamics 12 08-21-2009 10:20 PM
Boat tails trikkonceptz Aerodynamics 9 09-03-2008 11:58 AM
Rear Wheel Boat Tail Fabrication 2003protege Aerodynamics 1 07-24-2008 05:16 PM
Vacuum forming--may be useful for boat tails, etc.. Otto Aerodynamics 12 03-30-2008 01:02 AM
