Paul's how NOT to convert a Metro
So I have been reading a lot about conversions, and I am hoping to incorporate everyone's mistakes into one vehicle. I decided that too many people have successfully converted Geo Metros to electric, and that info is out there, but no one has yet described how to screw it up. I intend to fill that void. First and foremost, electric motor selection is crucial. To fail miserably I need a motor either too big or too small. Too big sounds heavy, and I am a very lazy person so that doesn't sound like a good option. I'd like to go too small. Besides, it should make a good show with sparks and what not when it explodes. Then, there's the budget. Much like a bank CEO, I plan on getting PAID to screw up: I'll sell various ICE parts to make money and use a part of it to finance the conversion and use the rest to buy Sour Skittles. I am also hoping to get the attention of GM so they can hire me as a consultant, since I will have undeniable proof that electric cars can't work. The pay should beat my Teacher's Aide salary of less than $10K/year at the local middle school. I've started videos to chronicle my humiliation:
http://www.youtube.com/watch?v=w4gQOiPII0U |
Are you cereal? I mean, you're going to just screwdriver it on purple?
But if it's working, you shouldn't... Oh. I get it. HA.
I have faith in you Paul :)
wtf
I would suggest welding up the wheel bearings, that's will not help loads.
Try to do something with no controller. You could have a sepex hardwired to spin around 2000 to 4000 rpm, and have to start by clutch slipping, and change speeds by shifting and binary pedal control (on/off).
Another thought is to do a series motor with a really big, heavy flywheel to give you time to engage the clutch before the motor spun up fast enough to spontaneously disassemble. Batteries on the floor beside the driver, with a jumper cable, makes for the cheapest switch, plus the bright flashes of light helps to warn away other drivers, who you'll now have trouble seeing anyways due to these bright flashes of light. Of course, safety first, be sure to wear safety goggles and to cover the batteries with a tarp in case they explode. |
Subscribed.
I've got to keep watching this channel. Cool!! |
I had no idea I sabotaged the opportunity to charge huge consulting fees to GM by making the ForkenSwift. I will play close attention!
Hmm... I'm working on a scooter conversion and have several bits from a 50cc variator left over, that might suit your purposes Paul :)
I think you should put at least one battery under the passenger seat, leaving the metal pan of the seat exposed, so that when someone sits on it, it shorts the battery, a'la Volkswagen Beetle.
LOL, been there :) Nice of those German engineers to pad the seat with hay :)
The unexpected accompanied ignition event blew my cheezy air cleaner off too. |
While I've had a battery explode on me, it's never been the result of the VW syndrome... I've only had anecdotal experience with the problem, and seen the aftermath of it (after letting the acid sit for a few months due to an insurance claim not being processed correctly). I also was commissioned to help clean it up and take care of the damage.
Thanks to everyone for helping me with such great ideas for failure! Keep them coming!! In the meantime, I uploaded a video of a coupler that I think has a very good chance of not working. The stock piece called a "hub" took 3 tries for me to finally buy the right size: 1 3/16". At this point, I am very angry because I was hoping to be MAKING money from this project, and here I am out $5.49 for the coupler. I feel like ripping a piece off the ICE of the Metro and putting it on eBay. I uploaded a new video. There are two setscrews there, I'm going to add another two to the motor section, then put in four for the clutch center portion to make sure it's nice and tight.
http://www.youtube.com/watch?v=YmIqlzLfmiY |
Set screws AWESOME!!! You should only need one, make sure the slop is all on one side.
Also, do the final line up and adjusting assembly of your adapter while texting, or in the shower, or while texting in the shower. Also, DO NOT WELD IT TOGETHER, if some of the scale from the weld comes off while running it could cosmetically damage something. |
So... you remembered to over tighten those set screws, right? Once you're done over tightening them, remove them and weld the holes shut - the heat expansion on the piece will make it bind together, so you won't need welding and set screws to actually hold anything together. Sweet, ain't it?
I finished the coupler. I'd be lying if I said it was easy. First I used chewing gum to hold in the clutch center, but that didn't hold. I tried crazy glue but it just stuck my fingers together. Then I drilled four holes with a new set of drill bits I got at Wal-Mart. Those wood bits I had were taking too long. I started tapping one hole out when I realized I had the wrong size tap. Today, after work, I bought the right tap. I tapped two, then on the third one, SNAP! broke the tap. I had purchased the last tap at Napa Auto so I went to O'Reilly's. None there. Back to the farm supply store where I got the coupler (they are starting to know me there, they must think I'm a farmer) and got another tap. It was half price, should have gone there first. Tapped the fourth one, then spent a good deal of time getting the piece of old tap out of the last hole. Retapped it. Coupler appears solid, but I'm all tapped out....
I started painting the motor. I wasn't going to, but it seems like everyone is doing it. I'm guessing it must increase horsepower, so I'm all for it. I went with OSU orange. Go cowboys. I'm ready for the adapter plate. I wanted to go with plywood, but since I'm anticipating sparks, I decided against that. I have the template, just need the aluminum plate. Anyone know where I can find aluminum plate? |
Junk yard. Most of them will sell it to you if you can find it in the yard.
(I mean the places that you take scrap metal to, not salvage yards.) I think if you used some nice subfloor grade OSB, and a sheet of lauan stained a nice cherry color, it would accentuate that orange of the motor. Plus, fat people walk on the OSB all the time, and it doesn't spontaneously disintegrate, right? |
Thanks for the suggestion. I'll call around the scrapyards. Forgot to mention that, in the parlance of the locals, I am "fixin" to buy yet ANOTHER golf cart motor for $25. Now I'll have TWO diminutive motors to play with.... |
How much do you think it would cost to mail one of those?... LOL.
I've not been able to find any decent sized motors for anything less than $200 around here, and some of those need new bearings and such.
I think I'm going to do a few alt conversions and see if I can make them more efficient, since I have so many of them. |
Well, hook up enough golf cart motors and you will might have something. Do some series/parallel shifting on 'em. When they are all in series they get all the current your controller can give and are at max torque, when in parallel they get their fraction of the current but more volts and can spin faster. Poor mans EV shifting.
I'm still doing some research on exactly what needs to be done to make it work correctly, and I don't have a controller yet, and they're not the most efficient motors in the world, but if you have 20 of them laying around, it's probably more efficient to drain the batteries a little faster than to spend good greenbacks on a motor...
Brushed motors need maintenance far more often than non-brushed type motors, also... so the efficiency is a tradeoff with maintenance, to some degree. |
vpoppv, I'm partial to the controller method the Albanian coal miners used in this youtube video.
http://http://www.youtube.com/watch?v=unhXEQQk8G8 It's a sweet solid state solution to that nagging problem of controlling the inrush current of a heavily loaded electric motor.:D |
"Hey, Jimbo - check this out!" :rolleyes:
Other Makes:eBay Motors (item 260464883145 end time Aug-28-09 18:43:29 PDT) And I know that the hub I bought as a coupler was actually made to have a gear welded on it. Something like that might actually work..GM would be angry. Maybe I'll do it after I fry the current motor:D |
You can couple a dual shaft motor and a single shaft motor, then couple the other end of the dual shaft motor to your transmission. You can also use a planetary gear drive.
The electric conversion is already saving me money
So I spent the weekend cleaning out the carport. Now I have a clean area to work in with plenty of room. I have already started to make money on the conversion: my wife's car ate the air conditioning belt last week. I pulled the one out of the donor car and now it's blowing nice and cold again. The conversion saved gas (no trip to the parts store) and money (didn't need to buy a new belt). So there you go, I'm already profiting from my conversion. Here's a video that shows me almost fall on my butt. If you listen closely, at the end, you can hear my daughter's complete confidence in my ability to convert this car to electric.....
http://www.youtube.com/watch?v=0aJzmySGqL4 |
I thought for sure that the last video was going to be called "Geo Metro driver side mirror removal"!
Seriously though, nice to see another Metro EV conversion. That motor and coupler are looking pretty good. I removed the flanges on my clutch plate, but I think you should keep them. In fact, you should add some of those little kids turbine whistles to the flanges on the clutch hub. When you spin the motor, it will make a great siren noise! |
Maybe I can buy one of those eBay Geo Metro "turbo simulator" whistles for my coupler? Come to think of it, it should make plenty of nice noise when the set screws work their way out. (Insert smilie of crash here). On a completely different subject, the Geo I am converting came from Wisconsin. I think there's some cosmic relevance there.... |
I just got done pulling out the motor; I have never done that before and it went very smoothly. If I could just locate some aluminum plate for cheap, I could have something going by the end of labor day....
Also, find a welding shop in your area - they'll be able to hook you up clean metals at a price only marginally higher than their cost. |
Actually, I really could go with steel, and that's more abundant here than fried foods, but I'm too lazy to drill and cut that stuff.... |
For steel, you could always sandwich a couple pieces of body metal together, and glue laminate them, drill/mill as necessary. It would hold up just fine.
It would end up exactly like a MLS head gasket, only with sheet metal that would normally be used for body work. For mocking up purposes, if you have nothing else to work with, a couple straps of steel bent and bolted to the face of the motor, then bolted to any of the mouting points on the transaxle would allow you to straighten things out and mock them up until the plate gets there, and plywood or 1/2" MDF would probably work as well. Whatever you use as a temp plate until your stuff gets there, make sure you account for thickness of material, or else you'll end up with a "how not to measure twice, cut once" thread. |
