Phil Knox's aero-modded 1970 VW van
3 Attachment(s)
Hello all.There has been some interest in streamlining vans,and especially some interest in van boat tails.Al Glidewell has scanned the photos of my college project with the VW van and we're going to see if we can get them posted here.The work was done 1979/1980 for a senior project at Texas Tech.A 1970 VW Transporter was modified with 0.32-inch thick aluminum full bellypan,cardboard and duct tape rear wheel skirts,and aluminum-over-wood skeleton 18-inch boat tail extension with increasing curvature up to an exit angle of 20-degrees,as measured from the vehicles longitudinal centerline.---------------- The "kit" provided an 26.8% mpg improvement in mpg.Cd was estimated at 0.35-o.32,from an original Cd0.455.Mpg was as high as 35.5 mpg at a steady 55-mph.
http://ecomodder.com/forum/attachmen...4&d=1244319087 http://ecomodder.com/forum/attachmen...5&d=1244319471 http://ecomodder.com/forum/attachmen...6&d=1244319471 |
Wow, that's a huge improvement. I wonder how much of the improvement is from the boattail, and how much from the belly pan
I'm betting the belly pans didn't help much. - those vw campers had an almost smooth underbelly anyways, same as the beetles.
Would lowering it have helped at all? |
That is over a 25% reduction in Cd! That is substantial. I thought I was doing good with a 10% reduction in Cd with the aerocap for pickups!
No wonder you know a little about aerodynamics, you have been doing neat stuff for 30 years now! Thanks for sharing with us, Bondo |
Did you make any changes to permit engine cooling? Didn't the original design use the low pressure at the back to draw air through the engine compartment, exiting through vents on the back of the van?
Thanks for posting this, Phil. |
VWs exhaust the cooling air underneath
That really is an amazingly effective improvement. Thanks for sharing it with us!
I suspect some of the increase in efficiency was helped by it having a really bad .455 cd. When you start bad, any improvement is substantial. I suspect if I were to do the same with my van, which already has a cd of .35, I would be lucky to net the same percentage decrease, which would be a .26
The work is indeed nice and clean, though. Reminds me of an Airstream travel trailer. Looks like the rear tailgate was completely inaccessible; wouldn't that be a problem for a VW camper come tune up time? |
how much
belly
25%
cooling
percentage decrease
boattail/bellypan
Has anybody done work on the classic 80's Chevy vans? I've two of them (both 1990, one V6 and one V8) in Kuwait with a number of plans to play aero, however doing the underbelly I thought would give good gains, not? The van's floorpan is really a raft of cross members that stand out (or point down) like sails! I also plan to redirect air into the front wheelwells by opening the headlight housings, replacing the lights with small diameter lens-type headlights.
Of all things, I found dumping the clutch-fan (radiator fan) in favor of an electric fan (Volvo S80) not only resulted in massively eliminating engine vibration, but I also noticable improvement in performance, hence economy. On the V6 I've added a windshield (?) between the bumper and the front axle crossmember, and the result was tangible. Mike |
classic
CAR and DRIVER attempted a full-size van aero-mod in the latter 1970s.Their bellypan was of no benefit unless painstaking detail was applied. Your fan delete is one which is well known of and proven benefit. I would mimic the front of any modern van or pickup if you can.Smaller mirrors have shown measurable results. One and a half feet length of boat tail gave me 4-mpg.A receiver-hitch cargo box might serve you as a foundation for such a mod,with quick-on/quick-off capability. This is something "hard to park" curbside and better suited to long highway excursions. |
Thanks Aerohead. Great recommendations, and a lot of news/info for me to consider. I heard of another guy, some years back, that created a boat tail with canvass material which got "inflated" as speed picked up - it had an air inlet. This saved a lot on weight, and allowed for easy install or take down. Just a comment that jumped to mind...
Now, let me check up the recommends you sent me. Stay cool, take care. Mike PS: Oh, and the mirrors are killers! When doing long distances I simply fold them flat or (once) turned them horizontal. |
another guy
The Aerodynamics Laboratory at Texas Tech University did some model wind tunnel research for him. He does use ram-air to inflate the envelope,it's clever engineering. I wish he'd seen Walter Korff's boat tail design of 1963,or Baron von Fachsenfeld's design of 1930.They are both aerodynamically superior. Tech published an article about the fellow around 1990/91,I'll see if I can dig it out. There's a shot of the inflatable tail for the T-100 undergoing tuft-testing in New Mexico in the Phil Knox aerodynamic photo archive if you can find it. They work! |
sealing around headlights
Mike[/QUOTE] mikeemans, the idea is to seal up the high pressure area in the front of your vehicle. Air hitting the front of the van makes it inside through gaps and openings, swirls around and creates drag. You may want to consider making flat covers if you have don't have flush mounted headlights and "basjoos" the gaps. http://ecomodder.com/forum/showthrea...-gap-4736.html Phil, thanks for breaking down the aero gains on the VW. You are an inspiration and an asset to us all. I am eager for warmer weather to start on my belly pan and receiver hitch-mounted boat tail. I welded up the plug-in "stinger" over Christmas vacation. I should be able to start building from that this spring. |
I can see some of these Aero improvements in my near future. I too have a brick, 01' Power Stroke Excursion! Our personal best is 18.2 at 65mph all the way to the Oregon coast from Northern Idaho. What a fun trip, I squeezed 750 miles out of that tank full I got 41.2 gallons stuffed into the 44gal tank!! We had big headwinds and cross winds going through the Dales nearly the entire way, but fantastic mileage for us! Now to see what we can get with a slick belly pan, fold in the passenger mirror and a 18"-24" Kamma...if I can figure out how to get it on the rear with the 3 split rear doors! I was not able to post a picture of it, i'll attempt to do that later...i couldn't remember how to do that actually... :{)
Maybe a little typo?
Thanks for sharing--a very impressive build and results. |
0.032"
Appreciate the eagle eyes.I've no secretary to blame it on,so I'll have to beg for forgiveness on this one as well.:p |
Maybe my post failed. To re-iterate:
In another post someone mentioned PolyMetal. It's a signage material that dirt track modifieds use for those big-as-a-billboard wings. Aluminum and vinyl skins on a plastic core. I'm with you on the proofing. I typically Preview 3 times and Edit once or twice after I post. |
