Old 08-24-2008, 10:59 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I basjoosed my headlights today (sealed the surrounding gap)
basjoos (v.) - to make aerodynamic optimizations at a micro (vs. macro) level.
(OK, yes, obviously basjoos does macro too, but whenever I start nitpicking about some small aero detail, I instantly think about his silicone-filled panel gaps. The "basjoosed panel gaps".)
So, no, I don't have any pics to post yet, but today I bought a roll of 3 mm (about 1/8) thick peel 'n' stick weatherstrip because I was looking for a quick 'n' clean aeromod project to do before my next big one.
I fit the foam strip in the gap all around the driver's side headlight assembly. (I'll do the other side tomorrow.)
That gap ultimately leads into the engine compartment and under the car, so despite it being a small area, it's pretty much the top of the list in terms of where I don't want air to go unnecessarily.
I calculated a total open area of 43.2 cm2 around both lights, or 6.7 square inches.
Inconsequential? Mercedes didn't think so ("sealed joints on headlights"):
From thread: Mercedes modded C-class: Cd 0.25. Up 7.5 mpg over regular model (with other mods).
khafra (07-06-2011)
Old 08-24-2008, 11:39 PM   #2 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Wow... 0.25 Cd. I wonder how much of that is because of the FULL SMOOTH-SURFACED UNDERBODY PANELING? Looks like they don't consider the hubcaps a priority, opting for weight over aero.
I never gave that gap much thought but now that you mention it and seeing that pic... you're making me a believer. I recently removed my ad hoc smooth hubcaps and rear skirts because they weren't having any effect on my routes but this sounds easy/small enough for me to squeeze in before I get back to my real job of schooling.
Does Prius have a "show me" diagram like that? I'd be interested in seeing all their upgrades, plus those from the Volt. Time to call upon the mighty search engine gods!
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-25-2008, 09:38 AM   #3 (permalink)
Really? Are you able to detect a change as small as a couple of percent above the noise of normal variation?
I haven't seen one. If you turn anything up, let us know.
Old 08-25-2008, 03:51 PM   #4 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
There was some slight noise reduction but it didn't translate to my scangauge. I will need more testing though under more optimal conditions. The wind lately has been annoying (HEADWIND???) and another reason I needed to remove all the tire tape was because I was getting my tires rotated today.
Got a lot of questions about my grill block though... blue tape does that.
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 08-25-2008, 09:18 PM   #5 (permalink)
Greta - '00 Jetta TDI
90 day: 59.96 mpg (US)
Send a message via Skype™ to ChrstphrR
When I was fixing my inner fenders on my TDI (replaced one, coroplast-patched the other), I noticed that I could see HUGE gaps between my headlights and bumpers. I ended up stuffing 1/2" x 7/16" weatherstripping into the gap below.
If I need airflow into the engine bay -- well, that's what the vents for the Radiator and Intercooler are for, not "extra" venting via the headlights.
No idea what improvement it's doing at this point, since I'm still calibrating my Scanguage II. That said, I know sealing that up that gap into a dead space shouldn't be counter productive.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 08-25-2008, 09:36 PM   #6 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
I'd imagine the minor air ducting to the lamps is to dissipate the heat produced by the bulbs.
Old 08-25-2008, 09:48 PM   #7 (permalink)
azrealswrd: Ben suggested I use lime green tape for my temporary mods. Nuh uh. I bet your blue tape got lots of attention.
The fact that you thought it was quieter tells me that's probably a worthwhile aeromod.
ChristphrR: well, I did the other light this evening, and measured it. Total gap area (projected) around both headlight assemblies is 43.2 cm2, or 6.7 square inches - practically the size of a business card.
I figure: if I've got a business card sized hole smack in the front of my car that does nothing functional, and ultimately lets air into the aerodynamic torture chamber that is the engine compartment/underbody area, why wouldn't I cover it up?
GM obviously thought it was worth putting speed tape over the headlights (and other panel gaps) to squeeze max efficiency from the GM EV1 / Impact for its record setting speed run:
Will post pics of my weatherstripping mod in a few minutes...
Old 08-25-2008, 10:05 PM   #8 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I seen that on Christine when doing the front grill block (bumper block) and was surprised at all the air gaps! I was not at all concerned with an entire blockage after seeing all this..............
Old 08-25-2008, 10:18 PM   #9 (permalink)
Pics:
Above: the gaps! It's no Lexus.
The 3 mm weatherstripping. I cut this in half, width wise.
This worked out quite nicely: the strip was just the right size so I could position it in the gap and peel the backing off with it staying in place. Then I lifted up on the bumper to squish the adhesive down nicely.
Top view: the hood presses lightly against this.
No more business card size hole in the front of the car! Mercedes, eat your heart out.
I need to finish the quarter panel gap around the side marker portion of the assembly. I'll just use black silicone there since it's too small for the foam strip.
Old 08-25-2008, 10:47 PM   #10 (permalink)
Talking
Hrm, well, maybe I'll clean out the car, and put a fire extinguisher inside. (My Dad and I both have the bad luck of having vehicle fires, anyway...)
And MetroMPG - nice picture showing the before, during, and after.
The size of the gap under your lights looks a lot like what I saw under my car (different make and all). I used a broken DQ Blizzard spoon to help shoehorn my weatherstripping under the lights, sticking it to the bumper fascia on the bottom, and sticking the top weather stripping to the plastic lense, again, like you did.
Last edited by ChrstphrR; 08-25-2008 at 10:51 PM.. Reason: Saw the pictures and didn't want to double-post!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/i-basjoosed-my-headlights-today-sealed-surrounding-gap-4736.html
Posted By For Type Date
How To Get 99.7 Mpg From A Geo Metro This thread Refback 01-29-2012 12:28 PM
Efecto Magnus en el smart roadster? This thread Refback 01-24-2012 08:47 AM
100 mpg News, Videos, Reviews and Gossip - Jalopnik This thread Refback 12-09-2011 12:14 AM
Hypermiling stories - Jalopnik This thread Refback 10-09-2011 05:19 PM
[MDU] Maximas Down Under - View topic - Ecomodder.com This thread Refback 07-31-2011 10:21 AM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-23-2011 04:18 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 02:02 PM
smarteros.com This thread Refback 09-08-2010 06:14 AM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 06-14-2010 05:04 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 06-14-2010 02:02 PM
Firefly efficiency mods - MetroMPG.com This thread Refback 01-01-2010 05:39 PM
Maxima and Cefiro owners down under... - View topic - Ecomodder.com This thread Refback 11-02-2009 06:50 AM
