EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Picked up a solid 4mpg. 98 Cavalier 3 speed. (https://ecomodder.com/forum/showthread.php/picked-up-solid-4mpg-98-cavalier-3-speed-15954.html)
YukonCornelius 01-30-2011 11:04 AM
I'm loving this website. I was getting about 24.5 mpg with my Cavalier. I read through the hypermiling tips and began to use some of them around half a tank. I don't shut my car off but I do let it coast in neutral when I can. I've done a little p&g. I try to conserve as much momentum as possible, but I'm still learning distancing. I read one member say that the highest speed they've applied their brakes at lately has been 18 mph, that is skillful. I drive alot of 50-55 mph roads with many traffic lights, some on timers, it makes it tough. This has quickly become a fun game to do while driving.
I filled up last night and came to 28.6 mpg :thumbup: I'm excited, driving through a whole tank should put me up to about 32. I also just checked my tire pressure today, I'm 24-26 psi all around. Yikes. I'm going to bump it up to about 46 today.
I'm running Sunoco fuel.
glhman222 01-30-2011 09:07 PM
yah, that tire pressure is holding you back for sure, if you can, also try getting an ecomodder alignment
after that you should be around 35
CigaR007 01-30-2011 10:01 PM
Pardon my ignorance, but what do you mean by "ecomodder alignment".
euromodder 01-31-2011 05:53 AM
Setting the wheel alignment to be as straight as possible.
The more toe-in or out, the more drag is caused by the tyres not rolling straight on the road but being slightly skewed.
bhazard 01-31-2011 07:36 AM
They still used a 3 speed in 98? Did it at least have lockup?
YukonCornelius 01-31-2011 11:20 AM
TH 125. It does have lock up. I was thinking about the alignment. Once I hit a wall I'm going to use HP Tuners to write a leaner tune with a lower idle.
YukonCornelius 02-08-2011 11:55 PM
I'm pretty excited guys, I'm 435 miles into my tank of gas and my gauge is only at the 1/4 mark! Prior to finding this site I was getting about 340 miles to a full tank of gas. If I can get 500 miles by the time I hit the E then I got 35 mpg. 400 of my miles were with the extra weight of a passenger and luggage. I might throw a gas can in the trunk and just run it until it dies to see just how many miles I can go. This may be the first time I've looked forward to filling up.
Also, epa combined is only 23 mpg for my car.
YukonCornelius 02-09-2011 09:52 AM
Originally Posted by NateHale88 (Post 219420)
I don't suggest running it out of gas due to the fact that sediment from the bottom of the tank will clog your fuel filter and that's not fun haha.. I couldn't imagine only getting in the 20s in a 4cyl lol. I have to beat on my v6 Grand Am to get 24. Good luck!
I thought not having overdrive was killing the mileage but the epa rating for the 2.2 with 4 speed auto was still a average of 23, and only 1 mpg higher for highway. It's just a poorly engineered car. The drag coef. is .36. I also believe the factory tune is on the rich side.
YukonCornelius 02-09-2011 08:51 PM
34.8 mpg :thumbup: Just came back from my usual pump at Sunoco. I really would like to break 40mpg, time for more mods.
crossout 07-07-2011 02:09 AM
try driving at 50 mph... i have hit 42 mpg for almost 150 miles it was awesome!!! mine is a 3 speed auto and a 00 cavalier
