EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Pics of my aero tweaks on 2000 Camry (https://ecomodder.com/forum/showthread.php/pics-my-aero-tweaks-2000-camry-1938.html)
OfficeLinebacker 04-21-2008 07:34 PM
I've been playing with tweaks since I joined maybe 2 weeks ago.
Haven't taken pics myself.
Wife did to post on another forum as a kind of joke on me.
Since the pics are now on the web, might as well put them here.
Please comment/question as appropriate.
http://www.inovagent.com/random/DSCF0229.JPG
http://www.inovagent.com/random/DSCF0230.JPG
Arminius 04-21-2008 08:05 PM
Good start. Those blocks over the upper grill should probably be shortened so that they end where the hood begins.
brucey 04-21-2008 08:08 PM
Me and a friend did this:
http://lesbaru.com/stuff/aerocover.jpg
Completely out of tape. Don't feel too bad. That cover helped tremendously, so now we're working on a solid one.
RH77 04-21-2008 08:14 PM
Great Start!
Here's what "LostCause" suggested for a very similar setup on a T-100 Pickup:
Link to original post.
I also agree with shortening the grille-block to the hood end.
RH77
Arminius 04-21-2008 08:51 PM
The mud flaps should be taken off.
donee 04-21-2008 09:08 PM
Nope, they should not be removed from the car. They should be moved to the front of the wheel wells.
Big Dave 04-21-2008 09:16 PM
Unless there is unseen bracing, your air dam is too flexible. It looks to me like it will bend back, letting air under the car.
Arminius 04-21-2008 10:24 PM
Touche! :thumbup:
Otto 04-21-2008 10:46 PM
At speed, does the plastic sheet billow out into a smooth contour?
brucey 04-22-2008 12:22 AM
Yeah, slightly. I put some "ribs" across so it could only conform so much. It held up quite well for being all tape. Rode the interstate for an hour or so in a pretty hard rain storm.
