Planned mods to my Golf 4 Estate (stationwagon)
Go here to have a look:
golf.citrusdm.com If you only see one pic, click on it to bring up the other 'after' shot. *Disclaimer: That's not my car, I have a black one but I don't have any pics of it. |
Looks like a good start. A 3" suspension drop may be more for looks than for aerodynamics. You would probably get more bang for the buck by doing a full belly pan at stock ride height. These cars are already pretty low and broken oil pans are not uncommon on lowered cars.
I have a feeling you could be right. Perhaps 2" would be more prudent? I have a skid plate on already - it's a standard part as far as I can make out. The replacent suspension I've already bought is fully adjustable coil-overs so I can adjust ride height as necessary. The main point is getting air to go anywhere but underneath.
That just makes me want one even more.
6 more months of saving and I should be able to get one. Look at weatherspotter and his brother's rides to see how good wagons look eccomodded. (sorry to _______ for forgetting your username.) |
Thanks Jason, how do I look at Weather Spotter's brothers' car?
Good luck getting your own. I didn't like it much when I first got it but I love it now. |
Look at some of weatherspotters threads, his brother usually is there.
I have the aero trix (heavily modded 2006 matrix). My bother (soulster) has a mostly stock Kia soul and does not like the look of my car :(.
I will read through the thread and add my thoughts, I just wanted to clear up who has the car modding experience :) |
I like your car choice, wagons are nice mix between people and cargo and MPG :)
Mod tips (links are to our wiki mod page for that mod): 1. grill block is a cheep easy first mod. Grill block partial or full - EcoModder 2. smooth wheel covers Smooth wheel covers - EcoModder 3. belly pan Belly pan - EcoModder 4. Rear wheel skirts. Rear wheel skirts - EcoModder 5. side mirror delete. Side mirrors - EcoModder 6. Tire pressure to max sidewall. Increase tire pressure to max sidewall - EcoModder 7. Scangauge ScanGauge OBD-II computer - EcoModder The first 7 are relatively cheep and easy to do. 8- 10 are harder but sill very doable. 8. Kill switch. Engine kill switch - EcoModder 9. Kammback. Partial Kammback - EcoModder 10. roof rack removal. Roof rack - EcoModder 11 Full boat tail. Full boat tail - EcoModder this one is harder and will take some $$$ and time commitment. I just did it and it took me a strait week of work and about $300. Issues with lowering: 1. will prematurely wear out your half shafts. I have a brother who tests them at work, keep the angle the same. Any change will kill them 2-3x faster. 2. reduces ability to go over debris in road 3. reduces ability to drive through snow (might or might not be an issue for you, I need 6-8" in the winter) before lowering a car I would make a air dam to the same height and see if that scrapes or if it helps. It is also a cheaper way to get the same gain. Front air dam - EcoModder Is the car a gas or not? Manual or not? I hope this gives you some food for thought. I would also look through the other mods on our wiki, it will give you plenty to think about :) |
Thanks WS, I've got a few mods lined up but I'm waiting on the delivery of my ScanGuageII. Without that I don't know what I'm improving on.
I quite like the look of your car - persuading my girlfriend to get in something like that s a different matter entirely! I have a post in the Introductions section that lists all my planned mods but I've also been wondering about hydrogen injection. Any thoughts? |
Hydrogen injectors are placebos really, takes more current from the alt than produces extra power/FE to compensate
