Plastic engines
I searched for it, but I didn't find anything here, and while checking out some of the archives at The Knee Slider, I found an article about plastic engines possibly being a viable alternative for automobile/motorcycle engines of current production types.
Article follows: Plastic Engines – We Have the Technology – Is Anyone Interested? http://thekneeslider.com/images/2009...gine-block.jpg |
First comment -
From the looks, that block is just that - a block. It would seem that the primary friction/heat parts of the block will not be replaced, and this is discussed in the article. It seems like, if we can assume anything from that image, the bearing surfaces and piston sleeves will be part of a secondary "bed plate" that is either fastened/adhered to the plastic block "casing" (if you will). If I might add another point of discussion to this: What about the availability of self-lubricating plastics? Would they be viable for use in low-speed engine applications (Sub-1000 RPM max) where low heat and power generation are required? What about applications for air-engines? How about plastic parts for the parts of electric motors that aren't required to be metal by design? What exactly are the possibilities of manufactured plastic components? |
...I remember reading that article. At the time, I had a '72 Pinto with that Ford-of-Britain (FOB) 1.6L engine...got 36 mpg at typical 55 mph, of course, I'd done a few tweeks like change the stock 3.55:1 axle to 3.18:1; switch from breaker points to fully electronic ignition; and installed a "tri-Y" header from a Cortina.
a while back I got the notion that molded plastic vane-type stirling engines (with flexible vanes) could be built into the wheels of cars and replaced/recycled after 10,000 miles or whenever their performance begins to suffer.
but then i remembered that i'm not in charge of jack squat and even if i had the cure for cancer written on a napkin i wouldn't have a clue how to start a business making it. |
Carbon fibre can be engineered to take the stresses involved and ceramic coatings can deal with the heat and bedplates etc to take the bearings will handle that.
I suggest it is more a case of what will it cost , rather than can it be made to work. Even those very familiar with the technology (Ferrari for example) have yet to implement it beyond the cosmetic applications. Pete. |
Tough to beat plain ol ancient cast iron for cylinders. Hasn't been done yet that I'm aware of.
my accord has a pizza box under the hood. with hho.
...ie: a "plastic" spider holding "cast iron" sleaves and bearings in their proper locations.
Yes I did read it. Just sayin.
