EcoModder.com
-   -   Plus one tire sizing effect on mpg? (https://ecomodder.com/forum/showthread.php/plus-one-tire-sizing-effect-mpg-5441.html)
93Cobra#2771 10-07-2008 06:48 PM
Looking at upgrading from my 175/65/14 tires on 14x5.5 steel wheels to 185/55/15 on 15x5.5 aluminum rims with the same offset.
Overall tire diameter is very close and should make no difference.
I have not been able to compare wheel weights, but I'm hoping they will be the same or slightly lighter for the aluminum wheel.
How will the slightly wider tire affect me? I'd like to hear first person testimony from those who have done such an upgrade.
chuckm 10-07-2008 07:10 PM
A wider tire will increase your frontal area, so you will see a slight uptick in drag. Otherwise, I'm not sure.
cfg83 10-07-2008 07:21 PM
93Cobra#2771 -
Here's my assessment :
http://ecomodder.com/forum/showthrea...ires-2642.html
I didn't go for wider tires, so I can't comment on that. I think it would be detrimental.
Hope this helps,
CarloSW2
93Cobra#2771 10-07-2008 08:00 PM
cfg83 - you did go for a wider tire. A 195/65/15 is 10 mm wider than the stock 185/65/15 and slightly taller as you found.
What have you found in your mileage comparisons so far?
I'm wondering if the decreased deflection/ heat generation will cancel out any loss from the slightly wider tire? 10mm is less than 1/2" from sidewall to sidewall.
cfg83 10-07-2008 08:23 PM
93Cobra#2771 -
Originally Posted by 93Cobra#2771 (Post 65854)
carlos - you did go for a wider tire. A 195/65/15 is 10 mm wider than the stock 185/65/15 and slightly taller as you found.
Thanks for catching that! I will post that on the thread as a negative. I will calculate the added frontal area. I am thinking it will be in the range of :
2 (tires) * 0.39(10mm / 25.4 = inches) * 6 (to 8 inches of exposed tire)
There will also be a horizontal increase in exposed tire area because the tire is slightly taller.
My main conclusion is based on the GPS/odometer correction. In my fuel logs I document a +2% distance correction from what my odometer is reading. I would suggest that whatever tire you get, you do a GPS before/after comparison. That will give you conclusive evidence as to what the gain is,
Caveat: I didn't think to do a GPS before test, so there is the possibility that my odometer was already -2% before the new tires.
CarloSW2
93Cobra#2771 10-07-2008 09:02 PM
The pariticular upsize I have chosen is within .2% of the oem size tire. That is, if my memory is correct. I'm posting from my phone and too lazy to look at the miata tire size calculator.
I purposely want to keep diameter the same as I don't want to induce error into my odometer reading.
It won't be too much longer before I get the new tires, as my current ones are about shot. However I wonder if I can get definitive results as my mpg keeps increasing on each tank! Check my fuel logs and see my progress, mainly from refined driving techniques (and possible an über secret trick that I will share if it shakes out).
cfg83 10-07-2008 10:41 PM
93Cobra#2771 -
I actually don't mind this because no matter what the odo reads, I *know* it's (just a little bit) better, :) .
Is it possible for you to do the before/after GPS test? That would (hopefully) add a little more data to your tire mod. Even if you go with the same size tires, I would think that the odometer would read different going from old/shallow to new/deep tread depth.
CarloSW2
CapriRacer 10-08-2008 07:02 AM
As a general rule, wider tires are going to cause more fuel consumption - everything else being equal. The rolling resistance of a tire is mostly controlled by the amount of deflection, the amount of tread rubber, and the type of tread rubber used in making the tire. In your case, the amount of deflection is the same - the overall diameter is the same, the load is the same, and if you use the same pressure, that would result in the same deflection.
However, careful selection of a tire can change this. Just be aware that a tire with good RR generally does that by sacrificing the treadwear / and or traction. (the tread rubber compound part of the equation).
93Cobra#2771 10-08-2008 06:14 PM
Capri - wouldn't deflection me less due to the shorter and stiffer sidewall?
whokilledthejams 10-08-2008 08:15 PM
I actually made the exact same tire-size switch, and my new tires aren't exactly long-life or LRR tires, but my MPG has improved (however, I think it's mostly a function of my driving). At worst, the slightly wider tires aren't hurting to any extent that I can detect.
I also get a warm, fuzzy feeling from multiplying my calculated mpg by 1.02. It's like a bonus!
some_other_dave 10-08-2008 09:42 PM
Tire calculators will only give you a very general notion of a tire's actual diameter or circumference. The sidewall numbers are "general guidelines" only, and the exact size of a 205/60-16 tire (for instance) varies from manufacturer to manufacturer.
If you can, check on the Tire Rack website (or similar resource) to find the actual published diameter for that specific make and model of tire--or the revs/mile figure, which is roughly equivalent. Compare to whatever you are "used" to having on the car, or to the OEM tires if you can find the specs.
In general, you will lose a little bit of MPG going to a wider tire. It may very well not be enough to notice, though.
-soD
CapriRacer 10-09-2008 06:09 AM
Well, I fudged a little.
What actually happens is that the PERCENT deflection remains the same because "everything else was equal" and that would include the sidewall stiffness (if you grant that we are talking percent stiffness due to the shorter sidewall)
But that doesn't change the basic premise.
93Cobra#2771 10-21-2008 06:45 PM
Well, after all my research and such, I ended up having to go back with the stock 14" rim. As I mentioned, the tires were pretty worn. Noticed a hopping in the right rear. Pulled the tire, and tread was beginning to separate from the carcass/casing. In other words, you don't drive on a tire doing that, or you may see sever destruction of tire. So, I had to get tires today, and guess which size they had in stock.
The 185/55/15 was also a bit of an odd size, and about $25/tire more than the stock size. Guess I'll just do some moon wheel covers instead.
