Is It Possible Apply + Newton III Motion Law as Dynamic System in a Motor Engine Device
https://s3images.coroflot.com/user_f...eiaqzab_gq.jpg
Is it Possible to Apply Physically Newton's Third Law of Motion as a Dynamic Cycle System in a Motor Device in a + Positive Way? 3rd Thermodynamic Law Applicate in a Power-Plant Device. The Reaction at From of the Action. New Torque Power. It’s a simple Plus Formula of the Interaction of the Two Powers: 1/Action, + 2/Reaction = Retrodynamic. / For every action there is an equal and opposite reaction. 2 Forces in 1 System. RETRODYNAMIC Effect - Dextrogiro/Action => vs <= Levogiro/Reaction Phenomena Effect. / Rotor/RPM VS InFlow/Way. 3d Thermodynamic Law Applicate in a Power-Plant Device. The Reaction at Front of the Action. New Torque Power. It’s a simple Plus Formula of the Interaction of the Two Powers: 1/Action, + 2/Reaction = Retrodynamic. "Changing rotation inside a mass makes it possible to change its inertial properties. It is the equation for a jet motion without rejection of any mass.” Albert Einstein. The logic of creation of an inertial propulsion system is thus: Any motion is rotation ---- Rotation of a matter generates a space-time Torsion ---Torsion of space - time is described by Ricci torsion --- Ricci torsion is an inertial field-----the rest mass of any object is determined by its inertial field---- operating by fields and forces of inertia inside of mass we can create inertial propulsion system which moves according to the equation [m (t) dv/dt =-vdm/dt]. Newton's Third Law of Motion: III. For every action there is an equal and opposite reaction. It is the sum of both (two) Forces - one to other / Are two Forces in one system. The formula of the Retrodinamic effect is a simple mathematical summation. What is Dextrogiro plus Levogiro, gives the result of the sum, of what is the total, which is the retrodynamic effect. But keeps doing Exponential. Retrodynamic Effect, are two Forces Actives in one system. It's like when the Star Trek Enterprise Spaceship Accelerates into the depth of space but spinning 2Two Opposites Forces (Like the Ying-Yang Concept) on a Central Axis in a Rotary Manner Way. *State ofthe Art-Novel InFlowTech 1Gearturbine RotaryTurbo 2Imploturbocompressor From Macro to Micro https://padlet.com/gearturbine/un2slbar3s94 * ·RETRODYNAMIC Effect / Some Points of View: I always explain it well, but another thing is that you don't understand it. As if it were an everyday question. And they don't take it as a disruption, which changes schemes. Because they really wouldn't even know about it. Being a subject that nobody has ever really dealt with. * And also to you can see it as an encripted information. And I know the best translator, for sure. And they don't take it as a disruption, which changes schemes. Because they really wouldn't even know about it. Being a subject that nobody has ever really dealt with. But the concept it's a simple sum, then keep going to increase the phenomenal interaction. Let me make a simple caparison: One Turn is One step, OK, Well in this particular case. When you do One Turn is One Step, And Then is another turn are gone to be Two Steps. And in the next turn are gone to be Four steps, And the next Turn are gone to be 8 Steps. Etc... Really to to be able to explain it, needs to invent a new Mathematical Signal. Brand New. I Tell You. Its Like That. * I'm going to explain them perfectly well. We are going to make a comparison that each turn of the Rotor (applied in my case/Gearturbine) is a Step. It's fine. And So now when the rotor rotates with the power of the mechanical drive (Action). And furthermore, it has the internal flow contrary to its rotation (Reaction), but in favor of the individual blade attached to the gear with planetary rotation that activates the Rotor. In such a case they are two forces in a single system. * Maybe it doesn't have the best translation, but that's something else, that's not the point. But that would in no way be something that could belittle his qualities and technical virtues. And at the end of the day, all the explanations you can have are in the operation of the system. And this could not be easier to appreciate, Summed up in a simple sum. And in this case of 2Two Forces: 1Action + 2Reaction Applied in a single cycle, and thus also a single system. ·A) 1Action VS/+ 2Reaction = ? ·B) 1DestroGiro VS/+ 2Levogiro = ? ·C)1Rotary Move VS/+ 2InFlow Way = ? Note: ·I use the "VS" Because the dynamic interaction is front to front, that's why. ·And is Added force one to the other, that's why I use the Sume/Plus mathematical symbol. ·A, B, and C are the same situation with a different word, from a different, technical view. Other Note: If somebody doesn't understand Cut be because of some reason. Not because my responsibility. * I deal with the Requirements of a new mathematical symbol, in order to explain the Retrodynamic Phenomenon that occurs in an invention that I am developing. It is called the "Retrodynamic Effect" and it is created by having a situation of an axis turning in the opposite direction in a rotating system and in this way a great force is created. And there is currently no mathematical symbol that can explain it. __________________________________________________ ___________ Latest InFlow Generation: State of the Art Novel InFlow Tech: ·1-Gearturbine Reaction Turbine Rotary Turbo, ·2-Imploturbocompressor Impulse Turbine 1 Compression Step: ·1-Gearturbine: Reaction Turbine, ·Rotary-Turbo, Similar System of the Aeolipile ·Heron Steam Device from 10-70 AD, ·With Retrodynamic = DextroGiro/RPM VS LevoGiro/InFlow, + ·Ying Yang Circular Power Type, ·Non Waste Parasitic Power Looses Type, ·8-X,Y Thermodynamic Cycle Way Steps. ·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, · InFlow Goes from Macro-Flow to Micro-Flow by Implosion/And Inverse, ·One Compression Step, ·Circular Dynamic Motion. Implosion Way Type, ·Same Nature of a Hurricane Satellite View. :p:o:( ;):cool::rolleyes: :):D:snail: |
See: https://ecomodder.com/forum/showthre...ion-39098.html
And a quote from that thread: ********************* This clown has been here before, and before, and before: 2012: https://ecomodder.com/forum/showthre...red-23409.html. This thread does the best job of shooting down his technobabble and bogus patent claim. 2015: https://ecomodder.com/forum/showthre...ine-31644.html 2019: https://ecomodder.com/forum/showthre...2-a-37890.html Edit: At least he's smart enough to not post his nonsense at physicsforums.com. His post would be deleted in short order. ************************ With one change. He posted at physicsforums.com and was immediately spam deleted. A spam delete at PF means that all trace of his annoying presence was removed. |
Batteries already made it obsolete.
'motor / engine'
Perhaps you'd like to decide which one it's going to be.
A 'motor'. Or an 'engine'. Or, perhaps the energy source, and we'll sort it out on our own, since you haven't. And how about hiring someone skilled in technical writing, who can manage a linear, coherent narrative, from beginning to end. Also, the American Bar Association may be interested in your particular talents. |
5 Attachment(s)
I think funding gatherer of questionable integrity is a job that is going to be made obsolete by AI:
Welcome, my dear customer! Allow me to present to you the most innovative, efficient and revolutionary machine of all times - The Perpetual Motion Machine! This machine works based on the retrodynamic effect, which allows it to produce continuous motion without any external source. Its design is inspired by the Newton 3rd motion law, which states that every action has an equal and opposite reaction. The Dynamic Cycle System consists of a series of interconnected mechanisms that work together in perfect harmony, resulting in unparalleled efficiency and reliability. One of the key features of this machine is the Dextrogyro effect, which refers to the rotation of the gyroscopic element in a clockwise direction, producing a powerful and smooth flow of energy. Another remarkable characteristic is the Jet Motion, which generates a high-pressure stream of gas that propels the machine forward, creating an uninterrupted flow of energy. The Levogyro aspect of this machine refers to its capacity to counteract the Coriolis effect, which is the force that occurs due to the rotation of the Earth. This means that the machine will be able to maintain its constant motion, regardless of its position on the planet. And last but not least, the Imploturbocoompressor is an innovative technology that allows the machine to compress and expand the air within the system, creating a powerful vortex that maximizes energy output. In conclusion, The Perpetual Motion Machine is an extraordinary invention that will revolutionize the world of energy production. Its cutting-edge technologies, retrodynamic effect, Newton 3rd motion law, dynamic cycle system, dextrogyro, jet motion, levogyro, and imploturbocoompressor make it a reliable, efficient, and never-ending source of energy. Do not wait any longer, seize the opportunity to own this extraordinary machine today! https://ecomodder.com/forum/attachme...1&d=1679665225 |
Text prompt:
https://ecomodder.com/forum/member-f...465b4ae06f.jpg Analysis: No Gothic arches or cupola. No two stories. No uderstanding of dynamic tension structuring. I think I dropped a leading 1 from '120FT'. [sigh] I guess I'll have to do it myself. |
I deal with the Requirements of a new mathematical symbol, in order to explain the Retrodynamic Phenomenon Effect, that occurs in an invention that I am developing. It is called the "Retrodynamic Effect" and it is created by having a situation of an axis turning in the opposite direction in a rotating system and in this way a great force is created. And there is currently no mathematical symbol that can explain it. * The Mathematical/Physical Symbol. What is required for the Explanation and Application in the Formula of the Retrodynamic Effect. Which has the quality of being applied in the Gear Turbine Project. What would it be to join the Symbols of ·1- (+) Addition and ·2- (X) Multiplication. It would be a Symbol with 8 Eight Points: 4 four of the symbol of + addition and four of the symbol of X multiplication. This is because it is a sum that continues to repeat the 2 Two forces the Action/RightRotation and the Reaction/Levorotation. The 2 Two Forces uniting, increasing each other into one. And is called “MULTIPLUS”. And in this way increasing its Power considerably. a sum that is multiplied and/or a multiplication that is added. When Active of the Rotor/action of the system and the internal flow/reaction that does it in the opposite way (in favor at the Blades circular move. Thats Why) applying in the individual vane connected next to its partner Gear internally fit in a planetary way internally in the casing, in this way. This is because that is how it works, they are the union and interaction of two forces face to face, front to front and therefore two symbols. DextroGiro and/or LevoGiro. Action And/or Reaction. + and/or X. * "a rotor spinning one Way/DesxtroGiro, and the inside rotor flow Goes VS in the other at front against contrary/LevoGiro" But the Blades (with the Gear) move in favor at that circumstances. Thats why is possible. The Interaction of two forces to make One. That Particular Mechanics Technique Goes increasing Two forces in One: Force1/Rotor-DextroGiro VS Force2/inFlow-LevoGiro. front to Front. |
