Post your "Failure Stories" and lessons learned from unsuccessful modifications
I wonder if ecomodder would benefit from an "Unsuccessful Stories" or "Less Successful Stories" forum to combat the effects of publication bias. In particular I'm thinking about A-B-A tests like the smooth wheel cover wiki - Smooth wheel covers - EcoModder.... we know that there should be a lot of variability in the results depending on the stock wheel covers...
Separately, the "what-not-to-do" lessons in materials are often quite valuable: i.e.:
There are some other areas where encouragement of failure reporting may be helpful:
Is it a good idea, or unnecessary? |
My tiny mod, the wing-shaped antenna stalk, generated a couple of fails:
- Make sure your mods don't deform under mild pressure e.g. circumstances you can expect in real life. (winglet mark 1 deformed and split open) - Don't ever try to speed up glue bonding in an oven, not even at very mild temperatures, unless all materials used explicitly need that kind of treatment. (winglet 2 deformed just enough to be useless in the process) - Make sure that whatever you fix to your car is secure enough to not come off on the highway. (winglet 3 flew off and landed on the highway, making a big rig behind me slam the brakes - for less than 1 gram worth of clear plastic... !!! ???) You should take extra care with pizza pans and other aero covers. Rule of thumb; they should be fastened so sturdily that you cannot pull it off again even when using full force. Every square inch can generate a pound of force pulling on it at highway spreeds. Aerial winglet 3, though tiny, was so tight that I had to use a lot of force to push it over the antenna stalk. It came off at 55 mph nonetheless. But I was happy; it did prove my point that the drag on the stalk was substantial, and so would any mod reducing that. Don't put a hair drier under your hood. It might cause a fire. It did not on mine, but it did not heat the engine either, at least the effect was minimal. A block heater might work. A hair drier though wastes just too much heating everything else under the hood but the engine. It did melt the snow on the hood, but I can just wipe that off anyway. |
"LESSONS LEARNED...the hard way"?
Front top grill block not ziptied down enough. Parachuted up causing major drag on the highway. Of course i can't see at all over the hood! Unknowingly lost about 10%mpg for 100 miles.
" Don't use dark-painted coroplast if dimensional stability matters. "
Christofoo, what do you mean by this ? Do you mean coroplast that has dark paint on it, or coroplast that is already a dark color, such as black coroplast ? And dimensional stability ? Can you expand on that please ? Thanks |
http://i184.photobucket.com/albums/x...psfd11bc4d.jpg http://ecomodder.com/forum/showthrea...tml#post375743 I've had the same experience with my passenger-side Corolla wheel-skirt, but not the driver's side skirt, just because I park facing east, passenger-side in the sun. There are applications where a little warping is not important, i.e. I haven't had a problem with the black coro on my upper-grille-block. |
I imagine A "Failures" Thread or Forum might be beneficial, As long as it does not get out of hand.
One of the pizza pans fell off my Father's caravan while I drove. I could see it close to coming off when I was parked at the stop before it fell off. I didn't think it would come off and we were in a rush, I didn't say anything about it to my Father. (Edit and note - I didn't say anything about it to him at the time, Not until after it fell off.) I had parts to put it back on properly, Too. |
I think a whole new forum is probably a bit much (there won't be a lot of threads).
But I suspect a "lessons learned from failure" thread in EcoModding Central would get contributions. I think you just started it. :) I'll move it over and edit the title. |
Failure? I have no idea what you're referring to. I don't know about the rest of you, but everything I do works perfectly the first time [insert sarcasm].
So far just changing the front spoiler into an air dam. I had it rite the first time when I tilted out the conveyor material at the bottom.
It worked really well but when I added side skirts I figured air dam and it dropped mpg 1.5its still that was 2 months later because I threw away the bracketts required to angle it forward at the bottom. Air dams work for some people but my sephia is pretty aero and it is just a big speed brake infront of the bumper now. |
