EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Power Antenna Cut-Off? (https://ecomodder.com/forum/showthread.php/power-antenna-cut-off-5851.html)
PlaysWithMatches 11-03-2008 02:47 PM
So, the Accord has a power antenna, which, with the old radio, would go down if you were using the CD player instead of the radio. I recently got a new radio, and the antenna is up whenever it's on, even if the CD player is being used.
So, my question concerns installing a switch to override the radio's signal to the antenna motor. I know it wouldn't be huge, but I figure this could help out some. Opinions?
TomO 11-03-2008 03:38 PM
Power Antenna Override
This is on Team integra.net but the color coding should be the same for your accord.
PlaysWithMatches 11-03-2008 10:48 PM
Hmm, any way that I'd be able to use a lighted switch, since there's 3 prongs, one for 12V, one for power source, and one to ground?
bbjsw10 11-03-2008 11:02 PM
To do a Lighted switch you would have to incorporate a relay. Light would be on when antenna is down this way. Put antenna to 87 and light would be on when up.
http://i219.photobucket.com/albums/c...w10/relay2.jpg
PlaysWithMatches 11-03-2008 11:06 PM
Oh, duh. Thanks. Now, to clarify, Antenna is to the antenna and Radio is the trigger wire?
bbjsw10 11-03-2008 11:07 PM
Yeppers. I ran out of space on my pic.
Clev 11-04-2008 05:19 PM
Cool. That's been on my list (I even bought the switch), but I so seldom listen to the radio, it's easy to just pop the trunk and plug the connector back in when I need it. (On the 90-93 Accord, it's behind the trunk liner, right below the antenna. Takes about 30 seconds, including buckling the seat belt back up.) I leave the antenna down the vast majority of the time so I get better reception on the FM transmitter.
PlaysWithMatches 11-04-2008 08:02 PM
Thinking about it though, wouldn't the antenna trigger wire be a 12v power source anyways?
bbjsw10 11-04-2008 09:20 PM
Possibly?!. If it is aftermarket then yes, factory sometimes used ground triggers.
Good way to find out.
PlaysWithMatches 11-04-2008 10:59 PM
Yea, it's a brand new JVC HD radio. I ought to just get out the voltmeter...
