Power generation & drag reduction (from "paddle wheel" mounted in rear turbulence)
Came across an interesting paper today that discusses power generation and drag reduction.
http://www.openfoamworkshop.org/2009...gnon_paper.pdf Quote:
Reading the introduction, so far, so good. I'll take a look to all the document
http://www.chemistryland.com/CHM107/...indTurbine.jpg from: CHM107 Energy: Quiz (I kid.) |
The rear is the ideal place for something like this, sure you are not going to get a whole lot of power out of it because there is not a lot of straight air flow, but it will help smooth the air flow and generate power at the same time.
I wonder if some of those piezo electric ribbon generators would do well, they have a very low power output but they also just need to flop around, like what happens when you have turbulent air flow. |
paddle wheel
Perhaps at some point they will do 3D modelling and wind tunnel evaluation.
Part of my brain says,eliminate the vorticity in the wake which the paddle wheel would harvest. The other side says,if you're stuck with vorticity,then make the most of it. The National Highway Traffic Safety Administration would have a say in the U.S.A. over any protruberance at the rear of a vehicle such as a paddle wheel. 'guess we'll see where it all goes. |
