EcoModder.com
-   -   Power steeing delete on a Matrix, project and how to (https://ecomodder.com/forum/showthread.php/power-steeing-delete-matrix-project-how-23348.html)
Weather Spotter 09-17-2012 04:16 PM
well I have been toying with doing a PS delete for a while now, just could not find an idler pulley to replace it with.
Well a friendly soul on my Matrix forum who was looking at my car thread and "got it" about why I do what I do. He was into the performance side of things but liked the aero mods for the high end speed and the cost savings and sent me a link to a PS delete racing pulley:
Toyota OEM Belt Idler Pulley - MR2-S, Lotus PS Delete - TOY-ZZIDLER van Toyota OEM - Monkeywrench
The price will make the payback longer then many of my mods but its about getting better MPG :D
so once it comes in I have a little engine project :)
Recommendations on how to cap/ drain the lines to keep the mod reversible and easy steering?
Frank Lee 09-17-2012 04:24 PM
I still have my pump all hooked up and simply pushed off to the side. I got used to the heavier steering quickly and lost the motivation to disconnect it all.
HyperMileQC 09-17-2012 04:48 PM
Does your power steering pulley is on the serpentine belt, or it is on a smaller one lonely? Because if it is on a small belt you could just remove it like we have done on the echo-troll. For the gain I guess like 0.05 - 0.1 LHK. You can't feel the non-asssisted tires above 10 MPH. I highly suggest you to do this mod. Also don't forget to keep your tires pressure high to make it even more easy to turn.
Weather Spotter 09-17-2012 05:01 PM
here is a diagram of my belt system:
http://i835.photobucket.com/albums/z...s/file-984.jpg
the PS pump is the one on the far left
it is all on one belt or I would have removed it a long time ago :D
my tires are at max side wall and have been for two years!
HyperMileQC 09-17-2012 05:06 PM
Such an annoying thing that the ps pulley is on the serpentine, it would have been way more easy if the ps pulley would have been on a single belt. Do you think a smaller serpentine would do the job?
You have the A/C Compressor?
Weather Spotter 09-17-2012 05:13 PM
If I change out the belt I mess up the routing, so I have a idler pulley on order :D
yes I still have the AC, its not worth the hassle to remove it in a way thats reversible and some days in the winter I need the defog help (only once every few years).
HyperMileQC 09-17-2012 07:01 PM
This seems to be a good idea. Totally remove the ps pump, replace with idler pulley. How many RPM's are you getting when idling with no accessories?
HyperMileQC 09-17-2012 07:03 PM
Power steering perhaps.
Weather Spotter 09-17-2012 09:06 PM
my great spelling shows up again :(
idle is about 700-900 rpms once warmed up. its 18-2100 until its warm. but I only idle at stop lights that are sensed (one in the morning I hit 90% of the time).
JacobAziza 09-17-2012 11:05 PM
When we removed PS from her matrix, I just bought a shorter serpentine belt, and rerouted it to skip the PS (and AC).
I drew out the belt diagram you posted above, and figured out a path that would turn everything the correct way while skipping the unnecessary stuff, then measured it with a piece of string and told the parts store the length of the belt I wanted in mm.
It took 3 trys to get the right length, and getting the belt on was a little bit challenging, but it gone on just fine in the end.
