EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Is a Prius inverter good for an EV? (https://ecomodder.com/forum/showthread.php/prius-inverter-good-ev-11242.html)
etc 12-01-2009 11:21 AM
I have converted several vehicles to electric DC systems. I recently bought this power inverter from a salvaged Prius. I have some wiring info on it but not much. Do any of you Prius experts know if this would be good for an EV controller? If anyone has any wiring info of any other input, I would love to hear it.
Brian
http://www.nwaev.com/prius1.jpg
http://www.nwaev.com/prius2.jpg
bwilson4web 12-01-2009 01:35 PM
Several of us have spare inverters but the electrical interfaces to the inverter are not well documented. Good Prius friend Hobbit has looked closely at an NHW20 inverter. I've been a little slow but it is on my 'to do' list.
I've always figured I'd have to 'scope out' the likely signals but that remains on my "to do" list.
The Prius MG1 and MG2 are AC motors in a "Y" electrical configuration, three-phase. I don't know what typical EVs use for motors.
Encoder signals from the motors flows to the hybrid vehicle ECU that drives the circuits. It uses a high frequency, 90 degree offset, stimulus/sensor coils around an excentric disk. But again, the exact signals are poorly understood.
Bob Wilson
bwilson4web 12-01-2009 06:27 PM
The Prius inverter is a fairly undocumented part with some impressive power electronics and internal control circuits. But Toyota has not been very 'open' about the exact specifications. The maintenance manual and SAE papers give some clues but it was really designed to work with the associated MG1 and MG2 in the transaxle.
What you have is an NHW11 inverter, 2001-03. Some of coarse specifications are available via Wiki:
  • MG2 - 33 kW, 44 hp
  • ~275 VDC traction battery - 20 kW maximum draw
  • MG1 - 14.5 kW, 19 hp (from memory!!!)
Now the interesting thing is a significant amount of power flows between MG1 and MG2 all the time. What I don't know (no one knows) is if you could drive MG1 and MG2 from a combined 33+14 ~ 48 kW, ~64 hp. But the battery leads were designed for something under 20 kW. Worse, to make it work, you'd need three traction battery packs and balancing multiple packs is not a trivial problem. So then you start looking at building this 275 VDC, +48 kW battery pack and that too is not trivial.
My interest is in something a little more modest ... house co-generation. It should easily handle generating up to 14 kW of pure sine wave from a running, parked Prius. This would be a very, very nice thing to have.
Bob Wilson
dcb 12-01-2009 06:36 PM
You have got to be kidding. That is like the absolute worst thing you can do with gasoline.
RobertSmalls 12-01-2009 06:57 PM
As a backup for when the power is down, a PriUPS would be very handy. As a method of displacing grid electricity, it's very wasteful and expensive.
bwilson4web 12-01-2009 07:24 PM
Relax folks, my co-generation plan is a little more involved than just the inverter. I already have Prius emergency power. Our family uses it for about 8-24 hours about 1-2 times per year. We've used it twice, already this year.
Bob Wilson
NeilBlanchard 12-01-2009 09:19 PM
Hi,
A fellow out in western Mass powered his house (or part of it) with his Prius for 3 days after an ice storm knocked out the grid -- and he burned just 5 gallons of gas. That was a nasty ice storm and the power company was sleeping on the job -- some other folks were without power for about 2 weeks...
etc 12-01-2009 09:46 PM
Just having it for a DC to AC 3 phase converter alone is worth what I paid, but I am interested in finding the wiring diagram for the harnesses. I know which is the DC input and the 2 AC motor outs, but I was looking for a way to find the throttle and sensor inputs. I may have to buy a complete harness and computer to get that info and when I do I will post the results. Thanks for the replys.
Brian
etc 12-01-2009 09:50 PM
If used with wind and solar power to charge the batteries, I think it would be a great way to displace grid power. Just a thought and thanks for the quick reply!
bwilson4web 12-02-2009 01:40 AM
I would recommend:
  • Toyota Prius Electrical Wiring Diagram - EWD493U (pp. 58,59)
  • A working NHW11 Prius and storage scope to work out the interfaces
But you are reaching the boundary of what is known.
Bob Wilson
