Project 60/60 Xfi Metro and Singh grooves
Maybe it's already been discussed and I missed it...
anyone following this? nice detailed pictures of a 3 cylinder Geo metro Xfi head modification SOMENDER-SINGH.com - Geo Metro XFI, '92 - 1 groove |
I am so doing that on my next project or rebuild.
What do these grooves do to cause these gains in power?
Don't the grooves add to combustion chamber area and cause more heat to be rejected into the coolant? Finally, can the grooves be used on a diesel? Ray Mac |
WTH? From my limited understanding of combustion dynamics and cylinder head design, those grooves provide two bad things:
a) a quench spot and b) sharp edges which are great sites for unintended flame kernels, ie detonation. The only positive I can think of are that they increase turbulence/swirl in the combustion chamber, and I am curious to know the explanation. |
OK I just read the front page about "Squish and Quench" and it sounds like pseudo-scientific mumbo-jumbo to me.
It seems that if this concept worked, we'd see spark plugs with these grooves in them. Hey, next time someone does a tune-up, take a Dremel and cut a groove in the first 1/4" of spark plug threads! Not to say it can't be true, but I can't help but think of the old "if it were a simple solution to increase MPG, wouldn't the major manufacturers be doing it already?" Are there any racing series where this is done? |
I think the grooves are a great idea. I have heard very good things about them from very knowledgable engine builders. I can't answer your question about why OEMs haven't caught on. It does say he has patented it though.
It's difficult to make a sand cast head with intricate details like these grooves in it, and labor to make each groove by hand before installation isn't justified by the ability to charge for the "Now with Singh-grooves!" head. That's my theory. Think how aerodynamically dirty stock intakes/heads/exhausts are, and then how much "cleaner" aftermarket units are. That sums it up. Cost to benefit ratio is too small.
I discovered that site a couple years ago, but just saw some new results on a Metro that caught my eye.
If you poke around the website for a hour or so, here's a lot of interesting observations the inventor has made. I like the guy's style, he doesn't pretend to know why it works, admits his data is far less than scientific (he's working in a little home workshop in India afterall). I have an extra head I'd like to cut and groove, just for giggles. But I won't be doing any A-B-A testing for everyone, I don't have the time for that. It sure would make an interesting engine dyno experiement where a guy could isolate the variables and take some reasonably reliable hard data. What I've read sound encouraging, sounds more believable since the guy isn't trying to sell anything, yet seems to share everything. something to ponder |
Here's an example of a guy that did it wrong and had to grind em out
grooves
Am I to understand that automakers are going to re-introduce the flat-head engine? Mr.Singh' groovy technology appears to show great efficiency in this type of engine technology,and perhaps he may see a rebirth on the horizon.-----------------------Also,I find it remarkable to use both turbulent and laminar in the same context.---------------------And no doubt, physicists worldwide,will marvel at Mr.Singh's ability to disassociate oxygen and nitrogen inside a combustion chamber.No mean feat!------------------------- Addititionally,since vapor- fuel demonstrates no fuel economy benefit over vapor/droplet fuel,it's surprising that a potentially more turbulent mixture would provide greater (over-unity?) energy release.-----------------------Charge turbulence occurs in the inlet tract,a function of Reynold's number and velocity and begins to subside by the time of BDC.----------------------------"Swirl" can occur inside the combustion chamber,a function of port,combustion chamber, and piston top design.Swirl usually leads to charge stratification and heterogeneous pockets of lean and rich mixture.When anticipated and designed around,this stratification can be exploited for certain purposes with up to three spark plugs/cylinder.-------------------------------- Torque is a function of Brake Mean Effective Pressure and has to do with optimum charging efficiency which occurs at approximately one-half peak horsepower rpm.The charge itself is the mass of fuel and air delivered to the cylinder. -------------------------------------- Some independent laboratory experiments would help us to better evaluate any inherent benefits associated with the Singh grooves.I remain very skeptical.
The only problem I have with this "improvement" from singh grooves is all the testimonials I read, the people had done other things along with it, resurface head, valves, tune-up's, etc. Who is to say these grooves did the improvement or the repairs they did.
I say if it won't cause detonation go for it. I would just round the corners slightly to reduce a "glow plug" affect. |
Wouldn't this also lower compression? thus power, also would this not cause slower, incomplete combustion in a correctly designed head?
I love the way they strip, rebuild, retime and adjust mixture and the grooves made all the difference :) |
I've been very suspect that the gooves do much. You are eliminating some of the squish areas that are designed to push the mixture toward the sparkplug and raising surface area of the combustion chamber.
I've never seen any honest dyno tests with emission tests on A-B comparisons without any other mods. I would also believe that if there is merit to them, that their size, depth, location, and angles would be extremely important and that merely hacking away with a dremel tool would never acheive the proper results. It would be like having a port grinder and guessing on how to modify your intake ports for more horsepower. Most of the time, you'd be making them worse then any improvements. |
eating a little crow,and enjoying taste of feet!
I beat up on Mr.Singh pretty good and out of common decency have "dug in" a little to see if there was more to his grooves.My 700+ page textbook on I.C. Engines had little in the INDEX, however I did find data scattered throughout the book and have amended the index for the future.------------------------- While I'm not vindicating Mr.Singh,there is a logic to the argument,however the text contradicts itself.Here's the deal.-------------------------------------- In 1923,Sir Harry Ricardo,England,received a patent for a "turbulent chamber" design for combustion chambers for an L-Head (flathead) engine.The design induced high turbulence near the end of the compression stroke.The turbulence helped scour the mixture close to the chamber walls,creating a more homogeneous mix,knock was reduced with the piston close to the head.Quench space was small,if autoignition occurred,it would have less impact, as end gas mass was small.End gas was cooled by proximity to cooler walls,spark plug was centrally located near the hot exhaust valve to reduce flame path and speed combustion.---------------------------- The design allowed for higher compression ratios without destructive detonation knock.----------------------------------- Combustion flames can be "laminar" or "turbulent".Laminar flames occur inside bomb calorimeters.Turbulent flames occur inside internal combustion engines.( so I don't understand why Mr. Singh refers to laminar flame with respect to IC engines).--------------------------------- Flame speed can be increased many times with turbulence.Turbulence sweeps unburned mixture into the reaction zone.Also,highly convective currents carry active particles into the unburned region.Turbulence can also arise from flame induction from microscopic explosions.Turbulence increases with engine speed.Combustion time is always shortened by autoignition,gives rise to higher pressure leading to knock.Maximum power is obtained when spark timing is adjusted to point of audible knock.---------------------------------- At the time my book was published,there was no way to quantify turbulent flame velocity,no units to work with,and no way to make tables,showing interrelationships as functions of temp,pressure,composition,etc..No scale had yet been discovered.------------------------- The book makes mention that turbulence,induced on the compression stroke is better than turbulence from the intake stroke,as it does not effect volumetric efficiency.(so far so good for Mr. Singh).------------------------ Here are some points to ponder.From the 1st law of thermo,the mixture cannot have any more energy than the constituent components.And since turbulence is nothing new to combustion chamber and piston design,the efficiency gains from turbulence induced by the grooves requires extraordinary proof.----------------------------- With respect to the Metro engine mods,here are a couple of things to consider.Compression ratios for engines are determined on a basis of engine friction.Compression ratio is a "weak" variable as associated with fuel economy.A 10% increase in compression ratio yields only a 2.3% increase in mpg.Increasing the CR also aggravates the formation of both NOx and HC emissions,requires spark timing to be retarded,which leads to extra engine heat,which requires a bigger or faster fan,and larger radiator.Starting requires more power,the engine requires higher octane.--------------------------- In addition,Tetra ethyl lead,formerly used in high compression engines was believed to create a catalytic effect at the combustion chamber walls,preventing the formation of free radicals and peroxides.Today,without TEL,someone else will have to tell us if current octane enhancers serve the same function.I don't have a clue! Altering an engine from factory specs can defeat the emission controls,potentially releasing CO,alcohols,aldehydes,ketones,phenols,acids,esters ,ethers,epoxides,and other oxygenates besides peroxides.------------------------------- Finally,in some cars with automatic transmissions,the engine can never be loaded to the point of explosive detonation,as the trans simply downshifts to reduce the load,something the Metro would not have available(yes?).------------------So it looks like there are kernels of truth to the premise of the grooves,I just don't know what potential gains can be expected if any,and the article is very subjective and not really loaded with useful quanta.Interesting though!
[QUOTE=bbjsw10;59333]The only problem I have with this "improvement" from singh grooves is all the testimonials I read, the people had done other things along with it, resurface head, valves, tune-up's, etc. Who is to say these grooves did the improvement or the repairs they did.
QUOTE] That's the same thing I thought, initially at least. I think I looged on to the site and was able to view more things inside... I've never received any spam or solicitations as a result. I read where one guy at least, compensated for groove volume by flycutting the head slightly. Then reading further, some guys simply flycut the head more, under the assumption the grooves are an "enabler" that allow the engine builder to run slightly higher than normal compression with no detonation. Slightly higher than normal compression definately give better cylinder filling and more power. More power per pulse can result in a more efficient use of the fuel you feed the engine. I can't recite combustion theory paragraph and verse like some can here, but I have been motivated to play with and better understand combustion chamber shape in race engines. A faster burn means less timing lead (advance) is needed, a good thing. Tightening the 'deck' (reducing the clearence between the quench area of the head and piston) on a normally aspirated wedge head design always seems to produce more power, irrespective of compression ratio. On a supercharged engine, tighening the deck has little effect. I believe the tight deck increase turbulance and charge mixing just before ignition. So, might those low-tech grooves cause 'jets' of air fuel mixture to futher enhance mixing just before ignition? Again, the guy isn't selling anything, so what's the motivation for telling big fish stories? I'm not sure, but I wouldn't use the old "Then whay aren't the automove manufactures all using if its so good" argument. Many large manufacturers have the 'not invented here' mentality, GM had been know for that line of thinking, for instance (not sure about today). It seems to me there are enough guys here who tinker, that someone objective has played with this idea. You know, layed hands on hardware... or grooves as it were. Anyone? |
I've tested the SGs in a four cylinder SOHC engine with crossflow parallel 2-valve bathtub chambers:
http://img136.imageshack.us/img136/8...isil007bn1.jpg http://img179.imageshack.us/img179/9...isil011bd0.jpg http://img223.imageshack.us/img223/7...isil004xm2.jpg http://img50.imageshack.us/img50/880...isil010dj2.jpg http://img34.picoodle.com/img/img34/...Hm_1a3d456.jpg I made lots of modifications in parallel with the SGs, so I can't scientifically prove anything. However this I can say: - Oil remains cleaner beyond belief. Even the running-in oil (usually black after 50 miles of bedding fresh rings) remained clean. - No trace of pinging, in spite of compression raised from 9.2:1 to 11.0:1. Not even lugging uphill flat throttle in summer with low octane gasoline (this I chalk to the grooves, my favourite benefit from them). - Smoother idle. - No tremble accelerating from 1200 rpm in fifth gear. - Fuel consumption improved a ~15% (this due also to higher CR and the other mods). As I see it, the grooves most definitely do not harm, and very probably do a noticeable amount of good, particularly by allowing higher CR without pinging. |
I am putting together a 1 liter for my wife's Metro right now, and I am going to try the grooves. Unfortunately, I bought the car with most of #3 piston in the pan, so I won't have any data to compare. I found a post that backs up most of TELVM's claims, especially the reports on oil cleanliness - Link is under post. BTW excellent work, TELVM.....that is probably one of the best looking SG jobs I have seen. I'll post what I find out after I put some miles on it.
Singh grooves in cylinder head - Speed Talk |
Grooves tested on 3-cyl Metro heads:
Somender Singh grooves in a Geo Metro! Grooved Metro number 2 Link to a long discussion on SGs at Turbobricks, pay special attention to what Automotive Breath (Randy Naquin) has to say, he the boss: Somender singhs groove theory tried. - Turbobricks Forums |
Test & analysis on the effects of grooves in a 3-cyl Geo Metro engine:
Garrett Robert Herning - Projects; Singh Test Results, AutoTronixs, LLC http://www.herningg.com/singh/Engine...20Analysis.pdf http://www.herningg.com/singh/Ioniza...20analysis.pdf http://www.herningg.com/singh/eng_1_sm.jpg |
The data and anaylis in the second pdf don't seem to agree.
Look at the HP rating through out the range and the non grooved head is almost always higher sometimes dramatically. The testing was also flawed because the data on combustion chamber size is smaller for the grooved head. If that is correct the grooves must be destroying the combustion process to lose that much HP. I only skimmed the report and noticed those. |
Less peak pressure at the right moment of piston travel can make more torque than higher peak pressure at the wrong moment of piston travel. Quote:
He could have used just one and the same cylinder head, first without grooves, then grooved. But he didn't. |
Thanks for the link, TELVM. I downloaded the file and am still reading through it.
Well, I went over the pdf files, looked at the bsfc values and I have a problem with the findings. I have a hard time believing that the grooves will lower bsfc at low/medium loads and rpm by 10 to 20%.
I put grooves in the chambers of my Calibra 2.0i 8V engine seeking not better fuel mileage, but resistance to detonation and more horsepower (I raised CR from 9.2:1 to 11.0:1, plus several other pinging-prone mods).
Then to my amusement I found that the fuel consumption had decreased at partial throttle. To me, more HP at WOT and more mpg at partial is a fine deal. But that's just me. This forum is also about lower fuel consumption ... mpg Research • Index page ... and they have a sub-forum dedicated to the grooves: mpg Research • View forum - Somender's Grooves Here's a thread on the subject at the TeamSwift forum (Suzuki Swift = Geo Metro): TeamSwift • View topic - Combustion chamber grooves=better economy?? |
I was refering to the tables/charts showing brake horse power and corrected horsepower as stated in the test result units. As for the differing combustion cambers, it stops any decompression effect from showing and even with that the grooved head HP dropped. |
My apologies Geebee, I'm not a native English speaker and didn't understood your words correctly. You are right, the grooved head made less power at WOT in this experiment.
Did you also see that the grooved head made more power, with better thermal efficiency and better brake specific fuel consumption, at partial loads? Also the EGTs were lower at all conditions. I'd like to remark that in this test the grooved head was standard compression ratio. To maximize their effects the grooves should be accompanied with a raise in CR. |
