Pumping loss reduction strategies
2 Attachment(s)
Over the years, manufactures have taken at least three different approaches to reducing pumping losses. The most well known here is lean burn, but cylinder deactivation and atkinson-like valve timing strategies are also utilized. So, which is the best? And is it best to combine strategies like cylinder deactivation and atkinsoning for differing power capabilities?
Here is what I have gathered as far as advantages and disadvantages of these three systems. Lean burn Advantages:
Disadvantages:
Cylinder deactivation Advantages:
Disadvantages:
Atkinson valve timing Advantages:
Disadvantages:
Increased EGR flow/Cooled EGR Advantages:
Disadvantages:
So far atkinsoning seems like the best choice, I wonder why Honda is still playing with VCM. Mazda gets the picture, and has implemented atkinson valve timing capabilities in its new skyactiv engines. I plugged my scangauge into my mom's CX-5 and noted that under normal acceleration the throttle plate is WIDE OPEN! Atkinson for the win! Here are some pictures of a VCM engine, showing one of its disadvantages: Here is the working cylinder head Attachment 20707 And this is the VCM head, looks alot cleaner doesn't it?Attachment 20708 On the top of the cylinder heads, its the complete opposite. The working head is clean, and the VCM head is dirty. I would assume this has to do with oil not being as hot on the VCM head and caking up. |
Another method OEMs have used is flowing more EGR into the intake. To get the amount needed, they typically have to cool it down. The newer Prius (2010+) and some of the Mazda skyactiv engines are already using this in addition to the atkinson stuff. IMO it should be retrofitable to older engines, but tuning is necessary, and obviously the engines aren't designed for it. It has some of the draw backs of lean burn in that a less air dense charge is harder to ignite and the flame propagates slower I would imagine.
Lean burn doesn't reduce pumping losses.
You might find this a good read:
Technical Overview of Honda's new R18 i-VTEC Implementation Quote:
For the record, lean burn also slows flame propagation.
The biggest draw back to EGR in my opinion is that it eventually clogs things up. The system should be designed to be serviceable. |
And I wish cylinder deactivation was more effective.
From some experimenting that I have done on my Talon, lean burn defiantly helps with pumping losses but as others have said it does slow flame speed. I can run lean burn and EGR hot or cold and it gets to a point where flame speed has the final say. I'm now working on my eight proto type lean burn pre-chamber(stratified charge). This new pre-chamber I hope will increase flame speed by a hotter kernel that will reach deeper into the combustion chamber.
Then I should be able to run normal ignition advance with a fast flame speed. |
