EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Purchasing an MPGuino (https://ecomodder.com/forum/showthread.php/purchasing-mpguino-20830.html)
gone.g 03-05-2012 08:09 AM
Hey guys,
Im new here and am willing to buy a Kit of any sort to get my hands on one of these.
Been waiting for 6 months for these to come available (tried purchasing twice through paypal but had to get refunded both times as there had been several problems)
Is anybody Able to help me Obtaining one of these or even get a full parts list
meelis11 03-05-2012 06:05 PM
Hi,
I have some pre-built mpguinos
More details here: http://ecomodder.com/forum/showthrea...ino-20362.html
gone.g 03-05-2012 08:28 PM
Originally Posted by meelis11 (Post 291362)
Hi,
More details here:
Hey bud,
Thankyou for that, I would like to buy a pre-assembled unit in full metric with seperate buttons if possible?
gone.g 03-05-2012 08:29 PM
Only problem is I can't pm you till I have 10 posts :P
gone.g 03-05-2012 10:37 PM
Also, can you supply without the LCD screen if we supply our own?
gone.g 03-05-2012 10:38 PM
And how long can you have the buttons extended by?
gone.g 03-05-2012 10:40 PM
And do you have any pre-made cases for these? Doesnt matter if you don't :P
meelis11 03-06-2012 04:08 PM
I can ship it without LCD if you want and give pin header for LCD soldering (-3.00EUR)
It has about 15cm cable so you can mount buttons right-side or left-side of the screen.
I dont have pre-made boxes but I can make similar like I have if you want (+2.00EUR)
gone.g 03-06-2012 06:12 PM
Pm sent :)
gone.g 03-07-2012 05:52 AM
EDIT*
If anybody could help me with a parts list i could build it myself here also? i did try searching for the parts list here but all i found was graphs :S
weighing up my choices :P
gone.g 03-07-2012 09:26 AM
If anybody feels like going through these to tell me if there right or wrong to build a MPGuino that would be wonderful :)
RJ11 - 50 x RJ11 Modular Network PCB Jack Connector 5222 6P6C | eBay
50x LCD - HD44780 16x2 LCD module Blue backlight+Free pin header | eBay
ATMega chip - 50PCS IC ATMEGA8-16PU ATMEL DIP-28 NEW GOOD QUALITY | eBay
switch - 300PCS 6*6MM 6.5MM TACT SWITCH TACTILE PUSH BUTTON | eBay
usb - 50 pcs USB-B Type Right Angle PCB Socket Female Connector New | eBay
470uf capacitor - 50 x 470uF 25V Radial Electrolytic Capacitor 8 x 12 mm | eBay
transistor - 50pcs MMBT3906 /PMBT3906/2N3906 TRANSISTOR GP PNP AMP SOT-23 | eBay
diode - !! 100pcs 1N4004 400V 1A Rectifier Diode DO-41 | eBay
oscillator - 50pcs 16MHZ 16 MHZ 16M HZ Crystal Oscillator HC-49S NEW | eBay
0.1uf capacitor- 200pcs 0.1uF 50V Ceramic Disc Capacitors | eBay
18pf capacitor - 50 Pcs 18pF 50V 20% 2mm Pitch Ceramic Disc Capacitors | eBay
1.2k resistor - 100 x Resistors 1.2K ohm 1K2 1/4W 250V 5% Carbon Film - Free Shipping | eBay
100k resistor - 100 x Resistors 100K ohm 1/4W 250V 5% Carbon Film-Free Shipping | eBay
L7805 regulator - 50 x L7805 7805 Voltage Regulator 5V 1.5A SGS-THOMSON - Free Shipping | eBay
28pin socket - 50pcs 28 pin 28pin DIP IC sockets Adaptor Solder Type | eBay
zener diode - Through Hole Zener Diode 1/2W DC 5.1V Voltage Regulator | eBay
10k resistor - 10K
220 resistor - 50 x Through Hole Carbon Film Resistor 1/4W 250V 220 ohm | eBay
50x atmega board - 1x Freeduino Arduino atmega168 Development Board PCB | eBay
only thing missing *i think possibly others* is the 'smaller capacitor... i have no idea what type that should be the yellow one that is
meelis11 03-16-2012 07:25 PM
Still some mpguinos available....
Mpguino is built in custom etched PCB and is same size like LCD (sits behind it, electrically it is compatible with "official mpguino"). I am using atmega 328
Price is 59euros + shipping (4.8eur) and paypal transfer fee (depends on buyer country 3.5-4.5% + 0.35EUR).
more info and pics
I have also made custom code (based on 0.75) just like I like it
extra features:
* added metric version (must choose before code/firmware uploading, no change possible in settings)
* bargraphs (shows 2min average 5-9L/100km - dropped 0-5L to gain better resolution)
* battery voltage
* trip cost (in settins you enter fuel price)
* current trip does not reset automatically after 2min engine off. Manual reset like tank trip.
* tank trip time in hours.minutes, current trip time is now available too
* saving tank trip data to eeprom (dont forget it when disconnected)
* some values are shown in integers (speed, rpm)
* removed leading zeroes (instead "012.45" shows " 12.45")
* added dragrace screen (0-100km/h time, 400m time and trap speed, calculated horsepower)
* using Atmega chip sleep mode (consumes about 5milliAmps versus 20milliAmps when in sleep)
allenh318 03-21-2012 10:10 AM
Compatability
Would this work on a 4.3 liter TBI engine? Will it correctly monitor a throttle body injection?
95CamaroV6 03-21-2012 05:15 PM
meelis, would you be able to ship a unit to the US? And how would I hook this up to an aftermarket speedometer? I would think there would be a SpeedSensor wire back there
meelis11 03-22-2012 04:31 AM
Hi,
I made quick search and found this page
http://ecomodder.com/forum/showthrea...ino-14552.html
more links here (use brauser search "TBI")
MPGuino - EcoModder
I dont know much about TBI so I cannot be 100% sure that it works. If TBI means that you have one injector, then it should work.
Meelis
meelis11 03-22-2012 04:35 AM
I can ship worldwide (same shipping price 4.8EUR)
Speed pulses should go into speedometer - how otherwise it can show your speed?
Check your speedometer manual.
Meelis
VXinOAKTOWN 03-25-2012 03:17 PM
I am also wanting a mpguino
VXinOAKTOWN 03-25-2012 03:18 PM
and need 10 posts to pm you
VXinOAKTOWN 03-25-2012 03:19 PM
very happy that you are building pre-assembleds
VXinOAKTOWN 03-25-2012 03:20 PM
sorry for pseudospam
VXinOAKTOWN 03-25-2012 03:21 PM
7
8
VXinOAKTOWN 03-25-2012 03:23 PM
9
VXinOAKTOWN 03-25-2012 03:24 PM
9.5
10
greenkz 03-25-2012 04:04 PM
11
doihaveto 09-10-2012 10:56 AM
12
13
doihaveto 09-10-2012 10:57 AM
14
doihaveto 09-10-2012 10:58 AM
15
doihaveto 09-10-2012 10:59 AM
16
doihaveto 09-10-2012 11:00 AM
17
doihaveto 09-10-2012 11:01 AM
18
19
doihaveto 09-10-2012 11:02 AM
20
doihaveto 09-10-2012 11:03 AM
21
meelis11 09-11-2012 02:32 AM
You can also connect me and order directly from MPGuino trip computer - MPGuino
Meelis
Quezacotl 09-11-2012 08:42 AM
Nice way to increase post counts :D
tony_2018 10-06-2012 06:18 PM
Hey I would like one as well but with a enclosure and reads mpg.
Quezacotl 10-07-2012 05:05 AM
MPGuino displays MPG by default, or what you meant? :D
