EcoModder.com
-   -   Put in Mobil-1 and tufoil today (https://ecomodder.com/forum/showthread.php/put-mobil-1-tufoil-today-3753.html)
regor 07-13-2008 01:39 AM
I've always made the switch to Mobil-1 around the 5 to 10K mark on a new vehicle. Always faithfully added tufoil.
Today, at the 8823 mile mark, I made the switch to mobil-1 (5-20w) and added tufoil.
Of course, I probably should had held up adding tufoil for a couple thousand miles to get the correct MPG with Mobil-1, but what the heck, I love the stuff.
I'll keep all of you posted regarding any increase in my mpgs.
On a side subject, I got a ticket right after leaving the dealership today. Stupid u-turn over solid double yellow lines. That will cost me. Hopefully traffic school will be a option given to me. First ticket in over 20-25 years. I've been kicking myself all day over it. On a funny side, when I called my wife about the ticket, her first comment was "They nailed you for driving too slow??"
SVOboy 07-13-2008 02:16 AM
Could you explain to fools like me what tufoil is?
regor 07-13-2008 02:36 AM
Engine oil treatment-
Tufoil Engine Oil Treatment
"Worlds most efficient engine lubricant for cars, trucks, boats and motorcycles. "
tufoil - Google Search
Lots of reasons why I love the stuff, but I won't go into details, however, I've been using it in all my vehciles since the early 80s. Solved the infamous knocking and pinging I had in a 98 Dodge Ram.
Yes, I've read the negative things about the stuff, but I'm one of the believers of it.
I've done oil Samples and analysis of all my vehicles from around the 5K mark to the 75K mark and sometimes into the 150k mark and have never seen any abnormal wear levels. With my 08 Honda, I had the oil sample drawn during this oil change and about 5K mark from now, I’ll have another sample drawn to see how my engine is doing. I’ll report what this latest sample reads when I get it.
BTW, if anyone is interested, I get my oil analysis kits (Preparid postage) from -http://getitlubed.com/
He’ll ship them to you for just under $23. They are the Amsoil kits, but don’t worry, I’m not a user of AMsoil.
regor 07-14-2008 10:25 PM
First day since the oil change. No real difference in MPG noted (Got 41.8, which is pretty close to my all time high in the mid 42mpg). Engine seemed smoother and shifted easier. I'll give my next report next Monday.
regor 07-18-2008 12:21 AM
Well, I was going to give a report on Monday, but since I won't be driving my civic until then, here's my weekly report since the switch to mobil-1 and adding of tufoil.
No real difference in MPG. Haven't hit the highest MPG I've recorded yet. Engine is runing a little cooler and rpms are lower. It seems like the car is shifting smoother, but no changes were made to the transmission.
This is prety much 324 miles since the change.
I had figured that I would see a increase in my MPG, but that hasn't been the case yet.
blackjackel 08-06-2008 04:05 PM
would like to see an update on this!
regor 08-06-2008 09:14 PM
No difference yet other than a smoother ride and a little lower water temp. Best MPG has been 42.7, but I got that prior to the switch.
KJSatz 08-06-2008 09:50 PM
Had you changed oil before? I read they use a thick oil to help break in the engine during its first few thousand miles. If you hadn't changed it, what was the "Oil Life %" your Civic was reporting?
I also have an 08 Civic LX, but mine is the 5-speed. I was wondering what kinds of driving you've been doing and what techniques you used to break 40mpg? As many details as you have the heart to spill, I'll lap them up ;). Thanks!
regor 08-06-2008 10:03 PM
First oil change was at the 5,000 mile mark. Oil life monitor was at 40%. Dealer put in Castrol 5/20w gtx. Next oil change was at 8823 mile mark. I believe the oil indicator was at 60%. This is where I switched to Mobil 1 and added Tufoil.
My daily commute-81 miles RT. From 500' to 4500' (Poway CA to Julian CA-Local Mountains). No freeway. 15 traffic lights, I believe.
I'm currently at the 10078 mile mark.
regor 08-06-2008 10:38 PM
techniques?
Buy a scangauge. That helps a lot. Do a search and see what settings others are doing.
Tire pressure-Whatever Honda states for your tires. I keep 36psi. Others will pump them up to the max that the sidewalls state. And check them.
Plan for the red lights. If you see a stale green, figure it'll be red when you get there and either shift into neutral and coast, or just take your foot off the gas and gradually slow.
Plan accordingly and don't use your brake. You want your car to be moving. Braking creates heat and friction which will slow you down.
Of course, keep the excess weight out of your vehicle.
Know your route and plan accordingly. I know my downhills and curves. I hit them so I don’t have to use my brake.
Keep your car clean. Dirt creates drag. I’m not talking about washing your vehicle all of the time, but use a duster on it.
Screw the person between you that is honking and flipping you off. At the worst, I’m doing 10mph below the speed limit when I plan my downhills and curves. Normally I’m doing the speed limit.
regor 08-26-2008 09:35 AM
3000 miles later and still no difference in MPG, in case anyone wanted to know.
Engine does run smoother and cooler.
nascarnation 08-26-2008 02:09 PM
thanks for the followup
no reason to think it should
viscosity is viscosity
if an oil change could add 1 mpg, the mfgrs would be all over it
but for the oil producers, it is a triumph of marketing
