Question about the Ford ZX2
I'm looking at a Red 1998 Ford ZX2 5 speed for sale, but it does not have ABS.
Does anyone know what I would have to Junkyard to add Antilock to the car? (rotational speed sensors, ABS computer, rear disks?) |
I do not like ABS brakes myself, but in order to retrofit that ZX2, you will have a lot of work and money invested including.............
ABS speed sensors ABS Module plumbed into brake lines PCM from ABS equipped car Replace axles with tone ring style wiring harness I would find one with ABS before sinking a small fortune into that one. |
The Mullet is wise. Keep shopping!
Judging by your name you are a Ford person. Step up to the Focus, as ABS was more available than in the Escorts. From 2000 - 2003 the Focus and Escort were sold side by side with the Escorts being mostly fleet and rental sales, which = basic. Look for an early Focus. |
I third!
I swapped ABS in to a supra once; totally wasn't worth it. |
Thanks for the info, guys. I am a ford person. You can blame Sean T. for my presence here, he brought me over from TaurusClub.com :p
I worked for Ford for 5 years and would tell you if you want a Focus, make damn sure it's a 2005 or newer. Don't EVER get an older Focus with the 2.0L SPI (Split Port Injection) engine since they are under-powered and not reliable.
I would buy the ZX2... They have a great style to them, and look very original.
When I first started working for Ford, the ZX2 was on sale brand new for $6999.00
I personally like the looks and sport of the ZX2 myself.
I live in MN too, and have one vehicle with ABS. I can count the times on one hand that the ABS has been engaged in the last 14 years... and even then, it was because I "locked 'em up" on purpose just to see if the ABS even worked. Forget about it.
Focuses are out of the question, then. I don't have that much money (hence the 10 year old ZX2).
I adore the styling of the ZX2. If I ever have the money, It will be part of my Ford Coupe Trifecta (Probe G2, Cougar FWD, and ZX2):D I just Sea-Foamed my Taurus 3 hours ago, and have since fallen back in love with it. I think I will keep it through the winter, at least. |
Welcome. Keep shopping. That is the same advice given to Miata shoppers, it is far cheaper to buy a car with ABS than it is to add ABS to a non-ABS car.
I really like my ZX2. I am learning to drive it to improve its FE. I'm sure I can do even better. |
