EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   A question directly about fuel consumption (https://ecomodder.com/forum/showthread.php/question-directly-about-fuel-consumption-23763.html)
elemein 10-22-2012 07:43 PM
Sorry for making this my first post; but I have a question I've been wanting an answer to for months now, and I just can't seem to find the answer for the life of me. I've asked my automotive teacher and my physics teacher, yet no one seems to know (yes I'm still a highschool student.) So I thought: "What better place to ask about fuel consumption than a forum revolving around exactly that?"
So here is my question.
Let's say I am driving a car with a 1.0 L engine (quite small; a Geo Metro perhaps?) I am cruising at 2000 RPM and have the throttle down at 20%. Let's say that the engine is currently running at 80% Volumetric Efficiency, and, it is also running a bit lean at a 15.5:1 A/F ratio.
How much fuel would I use?
Well, with MY understanding, here is my math.
1.0 L = 1000cc
2000 RPM = 1000 RPM worth of combustions as every cylinder fires only after every 2 RPM; therefore, 2000/2 is 1000.
-- So;
Fuel Consumption = 1000 (cc) * 0.20 (20% throttle) * 0.80 (80% VE) * 1000 (RPM worth of combustions) / 15.5 (:1 A/F ratio)
= 200 (cc) * 0.80 * 1000 / 15.5
= 160 (cc) * 1000 / 15.5
= 160,000 (cc) / 15.5
= 10,322.58 (cc)
So over one minute, I am using 10,322.58 cc's of fuel? Or over 10 litres of fuel per minute? That just seems absolutely insane! My math MUST be wrong!
Can someone please explain where I went wrong or perhaps supply the right way to figure this stuff out?
Thank you!
mort 10-22-2012 07:54 PM
A/F is mass (grams or pounds) not volume.
-mort
elemein 10-22-2012 07:55 PM
-mort
Wait wait, that sounds correct... Though, could you please elaborate?
So you're saying that the injectors are NOT spraying 15.5:1 of the VOLUME of the air going in, but instead they are spraying 15.5:1 of the MASS of the AIR going in?
UltArc 10-22-2012 08:20 PM
-mort
I believe pounds are weight, technically, but grams are mass. Correct me if I'm wrong.
But I am no assistance to this thread.
elemein 10-22-2012 08:21 PM
Yes, you are correct, weight is a measure of mass affected by gravity while grams are mass on it's own.
Though both are convertable to eachother :o
UltArc 10-22-2012 08:26 PM
454 grams to a pound, I believe.
elemein 10-22-2012 08:26 PM
Yes, I think that's correct :D
mort 10-22-2012 08:41 PM
You are wrong. The NIST allows "pounds" to refer to pounds of force usually abbreviated lbf and pounds of mass (lb). In all scientific and engineering measurement systems, and by convention, the weight of an object is the force on the object due to gravity, measured in the same units as force. So 454 grams of mass on earth weighs 454 grams. 1 lb of mass on earth weighs 1 lb.
-m
redyaris 10-22-2012 09:00 PM
As far as i know you can use pounds of air and ponds of fuel to do the calculations so you will have to convert volume of air to weight and volume of fuel to weight. at which point you can do the calculation to find mile per gallon.
elemein 10-22-2012 09:03 PM
Originally Posted by mort (Post 335675)
You are wrong. The ;; allows "pounds" to refer to pounds of force usually abbreviated lbf and pounds of mass (lb). In all scientific and engineering measurement systems, and by convention, the weight of an object is the force on the object due to gravity, measured in the same units as force. So 454 grams of mass on earth weighs 454 grams. 1 lb of mass on earth weighs 1 lb.
-m
Disregard my previous answer; this one is most probably correct.
Though sorry, mort, could you please answer my previous question?
