EcoModder.com
-   -   Questions about tires for my 2001 Corolla (https://ecomodder.com/forum/showthread.php/questions-about-tires-my-2001-corolla-10347.html)
rykoala 09-27-2009 02:19 AM
Hi everyone, I just got a 2001 Toyota Corolla as a gift. It only has about 55k miles on it and its a great little car. I will be researching things like the dams in front of the tires for small aero mods but really its going to stay stock for the most part.
I know that tires can make a world of difference. I need new tires, and so I am thinking about going from 185/65r14 to something of the same height but narrower. I think 155/80r14 is right in there or close. Would going to a narrower tire give me any measurable gains in the day to day driving? We do mostly around town stuff.
Additionally, I need something that's at least decent in snow and mild ice. I know that with 4x4's, which I used to dabble in, work better with narrower tires because it encourages the tire to dig down instead of float on top of the snow.
So, is this just a "dude, figure it out yourself" deal, or is there a well trodden path to follow?
Thanks a lot!
Frank Lee 09-27-2009 03:11 AM
All I know for sure is, I want to stand on a mountain and yell out your name.
http://i146.photobucket.com/albums/r...her/ricola.jpg
cfg83 09-27-2009 03:16 AM
rykoala -
This is what I did :
http://ecomodder.com/forum/showthrea...ires-2642.html
My thought process was to go to a larger diameter to make all my gears taller, but the merits of narrower tread has been discussed here as well :
http://ecomodder.com/forum/member-cf...e-car-2001.jpg
(maybe not *that* narrow)
Your proposed new tire size will also be a little bigger than OEM :
Tire size calculator
Hrmmmmm, I wonder if Prius tires would fit on your Corolla.
CarloSW2
rykoala 09-27-2009 08:28 AM
This is why all my newer logins have a different name lol. Its never pronounced right. Its Ry like Ryan, koala like the bear.
rykoala 09-27-2009 08:36 AM
Thanks for all of that! Lots of food for thought. I don't want to go bigger in diameter at all, just narrower. I have lots of research to do. A big factor is cost, though. I can't afford much right now. In fact, I may be buying some used tires to get through the winter until tax time comes and I can buy new ones. But if I can improve my situation at all even with just used tires, it'll be a cheap way to experiment with it.
Originally Posted by cfg83 (Post 130082)
rykoala -
CarloSW2
Daox 09-27-2009 09:28 AM
Going from 185s to 155s on my Paseo made a noticable difference at low speeds.
Also, make sure you pickup one of the nice new fuel efficient tires they've been making more recently. Here is a nice review:
When Round and Black Becomes Lean and Green
basjoos 09-27-2009 10:39 AM
If you can fit the Bridgestone Potenza RE92 165/65r14 used on the original Insight on your car, try them. I highly recommend them if low rolling resistance is your main interest as they are leaps beyond any of the other supposedly LRR tires (Michelin Harmony, Sumitomo HTR T4) I have tried on my car.
chuckm 09-27-2009 10:41 PM
I got the Viva2 Goodyear tires from Walmart recently for my 'rolla. Mine are 175/65r14s. I've got them pumped to 40psi and they are doing well for me.
http://ecomodder.com/forum/showthrea...ires-9502.html
