EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   RAM air Aero Tube (https://ecomodder.com/forum/showthread.php/ram-air-aero-tube-39963.html)
Tahoe_Hybrid 01-27-2022 10:16 PM
RAM air Aero Tube
i was thinking about an Aero tube instead of an air dam
basically this mod would capture the air and redirect it out the rear from under the car basically letting the air pass threw the car or truck
instead of trying to push it out of the way
what do you guys think?
freebeard 01-27-2022 10:50 PM
It depends. A 4" tube running the length of the vehicle would just waste space. Too much skin friction.
Modern practice has an envelope body that is hollowed out. MacLaren F1 and others. They try to get the air out behind the front wheels, then use a flat floor to set up for a difusser.
https://ecomodder.com/forum/member-f...gt-one-ms5.jpg
See the size of that duct? There're two of them. Here's a short duct on a Ferrari:
https://ecomodder.com/forum/member-f...64-images6.jpg
It's purpose is to move air away from the A-pillar. See also Viktor Schauberger's trout drive submarine:
https://ecomodder.com/forum/member-f...logicalsub.gif
It exhausts into a Coanda nozzle at maximum body cross section.
freebeard 01-27-2022 10:58 PM
What I'm interested in lately is the rim drive thruster. duckduckgo.com/?q=rim+drive+thruster&iar=images
These are for water, but a ganged rim drive air jet seems possible. This could make the duct a motive force.
Tahoe_Hybrid 01-27-2022 11:07 PM
so basicly adding a fan?
freebeard 01-28-2022 12:12 AM
It's getting away from the ram air (RAM air?) you asked about. A real example would be Malcom MacLaren Gordon Murray's new T50 supercar. It uses an auxiliary fan to draw air up into the diffuser on demand. But it robs air from about the rear axle line (above and below), not the front.
https://cimg3.ibsrv.net/ibimg/hgm/19..._100728239.jpg
Vman455 01-28-2022 04:37 PM
Originally Posted by freebeard (Post 662424)
A real example would be Malcom MacLaren's new T50 supercar. It uses an auxiliary fan to draw air up into the diffuser on demand.
I can't tell if you're making a joke? Malcolm McLaren was a British entertainer, nothing to do with the auto manufacturer. (The T50 has nothing to do with the auto manufacturer either; Gordon Murray has struck out on his own for this one).
freebeard 01-28-2022 05:38 PM
Sorry, Brain Cloud.
aerohead 01-31-2022 10:13 AM
aero tube
For lower drag, the trend is towards reduced body porosity.
And the lower the drag, the less porosity is needed, as cooling requirements drop with lower drag ( 2022 M-B EQXX ). A self-reinforcing feedback loop ).
The lowest drag automobiles known have zero body porosity.
I think you'd be shooting yourself in the foot.
Tahoe_Hybrid 02-06-2022 05:06 AM
i'm just trying to get the mpg to 30mpg which is completely do able without making it look like a aero civic
freebeard 02-06-2022 11:54 AM
vs
The question has become particularized.
30 MPG is a pretty low bar. What vehicle did you have in mind? And what is wrong about the way Aerocivic looks?
