rear bumper skirts
Well I got bored today and the aero bu has bitten me good. I was thinking would anybody know of or has put on there car, skirts on the sides of the rear bumper after, right after the rear wheel wells? I would think it would help direct air out and around from going underneath the rear of the car.. which is a horrible spot for it to be going. I do have quite a bit of gardening edging left... if seems like a good idea, ill try it out!
It tends to be done with full rear wheel skirts to keep the flow attached further along. This way it allows for a sharper edge at the rear of the vehicle which is better for aeroflow. Can also be used for a boat tail attachment later on
I dont plan on a boat tail, I do plan on full wheel skirts later on. I think im going to put them on to see what they do, I dont think it could hurt my mpg? The only thing I can think of is the rear wheel wells dont make a complete half circle, they cut off half way down on he backside, maybe the skirts would block some air that's trying to escape?
1 Attachment(s)
i drew this up real quick so your basically talking about the area behind the wheel well? I would just go get a sheet of coroplast and make 1 giant piece for it all.
Thanks for that!!! Yeah thats what im talking about, I don't have coroplast yet. Im on a tight budget right now, im moving really soon. Thats a good idea, ill probably do that once I get some, except I hope coroplast is flexible because after the wheel well, the bumper starts to angle inwards. I might put the gardening edge on for now, see if it helps. Im going to be doing a few long drives on interstate at the end of this week.
coroplast is basically a stronger version of cardboard. It'll bend to a point and beings its made of plastic can be molded using heat although it'll distort so you have to take your time with it.
What i like about coroplast is its pretty cheap. I get 4'x8' sheets of it for $13. I've heard where people get the same for $20 so look around. |
Alright, ill be looking around for some, thats not a bad price at all!
the plastic ones are made of the same material in fact coroplast is used to make most election signs, |
Yeah, I hope its not to late. That would be awesome, great idea! Now I just need to know where to get some...
apart from election signs try googling "sign shops near (insert close bigger town here)"
if all else fails and you can't find any try home dept its smaller and a bit more expensive though. BTW coroplast is a nickname that most people go by but its true name is corrugated plastic |
