Reducing drag on old-shape sedans (notchbacks)
1) M_a_t_t, this one is for you!
2) For people following the Aerohead / template debate, as far as I can tell, this video covers how Aerohead thinks the aero of all sedans behave. (Primarily, because back in 1987 - the year of the textbook Aeroheads most often cites - this is indeed how aero on sedans was.) But things have changed...a lot. So don't use this video to modify modern-shape sedans that have attached flow. https://www.youtube.com/watch?v=ea8FFmbYams |
Where/what is that?? Have a look around. this video covers how Aerohead thinks the aero of all sedans behave. wait.. are you aerohead? Nope. Perhaps I should have said: as far as I can work out from what he posts here, Aerohead appears to believe that the aero of all sedans behaves as in this video on old shaped cars. 1987 - the year of the textbook Aeroheads most often cites now im really confused.. Aerodynamics of Road Vehicles, 1987. Aerohead has repeatedly said he has not read any more recent aero textbooks. |
When I got the notification on my phone I did think "finally, something that I could more directly apply" :D
I was thinking I could just use that adhesive spoiler and run it along the edge of the back window/c-pillar. I hadn't though of raising the spoiler either. Do you think the angle of the spoiler matters? The stock one on my car points a little toward the front of the car, but if I'm making risers I could probably just account for that. |
In turn this dramatically changed: 1) the main cause of rear lift 2) drag coefficient 3) how rear spoilers work Old shape sedan (1986): https://d3lp4xedbqa8a5.cloudfront.ne...odore-vl-2.jpg New shape sedan (1988): https://d3lp4xedbqa8a5.cloudfront.ne...ommodore-2.jpg Even newer shape sedan (2013): https://carimages.com.au/6Gw6YT_rq4P...re-sv6-531.jpg Notice the change in rear window angle and C-pillar curvature. So yes, basing your understanding of airflow patterns on sedans on a 1987 textbook is highly problematic. |
The :) was for the over-specificity. For me it starts with the first four generations of the VW Jetta with it's raised rear decklid. ....in 1979. |
I think the "old" sedan looks the sharpest. I think my Fiat is one of my favorites in the looks department. https://ecomodder.com/forum/member-m...728-193858.jpg https://ecomodder.com/forum/member-m...11117823-n.jpg |
I adjust the angle of pitot tube by either adjusting the angle bracket at the pitot tube itself or at the suction mount. But I'd be assessing different drag values of a modified spoiler with the throttle stop technique, not the pitot. Pity you don't live around the corner, because it'd be a really interesting test to do, I think. |
