EcoModder.com
-   -   Reducing electrical loads (https://ecomodder.com/forum/showthread.php/reducing-electrical-loads-8954.html)
The Atomic Ass 06-27-2009 12:07 AM
How much do you guys figure dropping a 60W load from the alternator would save?
I'm considering dropping my DRL on the Burgman.
stevey_frac 06-27-2009 08:41 AM
60 watts is about .08 hp. Even assuming the alternator is only 50% efficiency, you'd be looking at a savings of .16 hp. I think the fuel economy increase would be at the limit of your ability to detect. However, it would make a difference, and everything helps?
-Steve
JacobAziza 06-27-2009 08:48 PM
You can save another 40-150 watts by changing all the running / signal / brake lights to LEDs (depending on the car/number of bulbs),
at least at night.
If you do both changes at the same time, it might make a difference you can notice.
Christ 06-27-2009 09:43 PM
The 'burg has a built in alternator, right?
It probably only produces about 10-20 amps, max.
For posterity, the one on my tractor's engine is built in (it's part of the flywheel). It takes about .6 HP to make 15 amps @ 12VDC. (According to Briggs, IIRC)
15*12 = 180 watts
Assuming 50% efficiency, 180 watts takes about .5 HP to make, the rest of the power loss is heat, I presume.
If your 'Burg makes 50 HP max (unlikely, probably closer to 30), you're looking at 1-2% of your total output being used for max load on the alternator. Relatively insignificant, but you may get something from it.
The Atomic Ass 06-27-2009 11:54 PM
at least at night.
I've tried that. The rear lights go in vertically through the bottom of the light pod, and auto-store LED's don't produce any viewable light from the rear.
And I don't have any money for anything else at the moment, unfortunately.
JacobAziza 06-28-2009 12:43 AM
You would just need a right angle bulb, like this:
http://www.superbrightleds.com/store...157-w30-ra.jpg
Product Listing - CAR
Or a multi directional one like any of these:
1157 1156 Superlumination.com leds (Automotive Replacement Light Bulbs, Headlights, Foglights & Lamps)
I didn't realize at first it was for a motorcycle; so it would save all the time, not just at night.
I use them in my bike, very happy with them.
They are kind of expensive though.
