Old 06-27-2009, 01:07 AM   #1 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 37.17 mpg (US)
Reducing electrical loads
How much do you guys figure dropping a 60W load from the alternator would save?
I'm considering dropping my DRL on the Burgman.
Old 06-27-2009, 09:41 AM   #2 (permalink)
Jalilah - '07 Chevrolet Cobalt LT
90 day: 40.57 mpg (US)
60 watts is about .08 hp. Even assuming the alternator is only 50% efficiency, you'd be looking at a savings of .16 hp. I think the fuel economy increase would be at the limit of your ability to detect. However, it would make a difference, and everything helps?
-Steve
Old 06-27-2009, 09:48 PM   #3 (permalink)
JacobAziza's Avatar
Big Orange Work Truck - '83 Ford F-250
90 day: 27.54 mpg (US)
Jessica's - '04 Toyota Matrix
90 day: 41.21 mpg (US)
Ninjette - '01 Kawasaki Ninja EX250R
You can save another 40-150 watts by changing all the running / signal / brake lights to LEDs (depending on the car/number of bulbs),
at least at night.
If you do both changes at the same time, it might make a difference you can notice.
Originally Posted by Piwoslaw View Post
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
Old 06-27-2009, 10:43 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The 'burg has a built in alternator, right?
It probably only produces about 10-20 amps, max.
For posterity, the one on my tractor's engine is built in (it's part of the flywheel). It takes about .6 HP to make 15 amps @ 12VDC. (According to Briggs, IIRC)
15*12 = 180 watts
Assuming 50% efficiency, 180 watts takes about .5 HP to make, the rest of the power loss is heat, I presume.
If your 'Burg makes 50 HP max (unlikely, probably closer to 30), you're looking at 1-2% of your total output being used for max load on the alternator. Relatively insignificant, but you may get something from it.
Old 06-28-2009, 12:54 AM   #5 (permalink)
at least at night.
I've tried that. The rear lights go in vertically through the bottom of the light pod, and auto-store LED's don't produce any viewable light from the rear.
And I don't have any money for anything else at the moment, unfortunately.
Old 06-28-2009, 01:43 AM   #6 (permalink)
JacobAziza's Avatar
You would just need a right angle bulb, like this:
Product Listing - CAR
Or a multi directional one like any of these:
1157 1156 Superlumination.com leds (Automotive Replacement Light Bulbs, Headlights, Foglights & Lamps)
I didn't realize at first it was for a motorcycle; so it would save all the time, not just at night.
I use them in my bike, very happy with them.
They are kind of expensive though.
List of "typical" electrical loads in a modern car MetroMPG EcoModding Central 13 08-08-2017 10:29 PM
reducing drum brake drag Gregte DIY / How-to 46 10-28-2014 11:21 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 11:27 PM
Electrical Drain fuelguy General Efficiency Discussion 1 01-31-2009 08:40 PM
The benefits of reducing weight tjts1 EcoModding Central 10 07-07-2008 10:37 AM
