Regear possibilities (01 Ford Ranger)
Been a while since i felt inspired to do any ecomodding. Been averaging 36 on my commute, on winter gas, so i have been feeling pretty good about that.
BUT I have an itch to mod something right now and I am leaning towards regearing. Right now I running 3.73 gears with 215/75r15s, and my best idea so far is to try and grab a 3.08 rear end out of an 1992 ranger, which is also 1" narrower on each side, and go with some 195/65r15 LRR tires (Michelin Energy Savers A/S??). By my calculations that should be 17.4% decrease in RPMs from the gears, and a 10.5% increase from the tires. Combined this should result in a 6.9% decrease in cruising rpms, with far less rolling resistance. It should also make it much easier to do a rear wheel skirt with the wheels sitting an additional 1" inboard. Any idea what i can expect from this gearing change? I am expecting a couple MPGs highway, but dont want to cripple my trucks 4 cyl. Is there any research about ideal % change or am I going to need and just figure it out as I go? |
And some weight savings are also a good measure. |
Unfortunately there is not much available for power/efficiency mods on this engine without spending big money... :( |
And it still seems to be the easiest mod to increase the efficiency in a 4-pot Ranger with the Duratec. Then, a supercharger would be needed to overcome the lower output due to the "Atkinsonized" cams.
A 3:08 might be a bit "tall" for the little 2.3l from a dead stop. Maybe research a 3:45 from a pre-'92 Ranger (shorter half shafts also). I think the next "taller" gear in the Ranger (pre-'92) was something like 3:27 (?). Too much gear from a dead stop and you might be wasting your "savings" in just getting up to speed. I am thinking about the 3:45's also. They seem to be about the "limit". the Duratech's probably make more torque than my little Lima so maybe you could get away with the 3:27 (?) but I still think the 3:08 is pretty tall. Just my opinion though.
