Renault Clio 2 Ph.3 Ecomodding Thread
2 Attachment(s)
Hi
In this thread i will post pictures and diagrams of my ecomodding work. First ecomodding job for me ,although not a very good one i guess, is a partial upper grill block. Using a piece from 5mm depron sheet and some clear tape i made this block for testing out temperature tolorances. |
2 Attachment(s)
also i've covered up some intake holes that lead to nowere ?! why did they put them there?
2 Attachment(s)
and finished job for today...
The built-in temperature gauge may not be accurate or clear enough . It's one of the reasons many of us run a ScanGauge ( Welcome to Scangauge Homepage - www.scangauge.net ( English Version ) sell them, and they're in Patras, Greece ;) ) UltraGauge (_____) : exact coolant temperatures. |
Also, while ecomods help to reduce your fuel consumption, changing your driving style is far more effective than many mods.
Driving slower will help a lot. It doesn't mean you'll need more time for a relative short distance (like 50 km or so). |
The built in gauge is far less than accurate , i have installed a car pc so i have all the readings through the EOBD port. Yestarday i did a 20km highway ride and the highest reading was 90c for about 10 seconds. Most of the time is was between 80-86 degrees and it is what i usually expect. Thermostat opens at 89 degrees so i think i am ok for now. As you can see the left opening which i've covered doesn't cool anything but the A/C compressor and the alternator so i think is useless for my engine , it is maybe usefull to bigger engines. Does mpguino measure temperature? that will be usefull cause i don't turn on the car pc always it pulls 5-6 amps and that i think can ruin my MPG |
I thought it did. But when looking it up, it doesn't seem to show coolant temperature. My bad :o |
I think it will be easy to hook up the temperature sensor to mpguino and that way i'll have the pc turned off when i don't need music haaaa!!!! |
New record for me yestarday maybe result of MPG software i've installed to my carpc so 6.88/100km 34.164 Mpg but i saw temperature readings as much as 98degrees celsius sometimes i don't know if that's normal but i hope it is...
1 Attachment(s)
Another Mpguino Came to Life :D
