Retro aeromods: Datsun 240Z factory bolt-on "G-nose" good for +5.5% mpg and +5 mph
Base / stock Z-car nose vs. "G-nose" version:
http://ecomodder.com/imgs/Z-Car-reg-nose.jpg http://ecomodder.com/imgs/Z-Car-g-nose.jpg Car & Driver, May 1974: Quote:
You'd think those bulky fender flares would slow it back down again. |
And the wider tires they stuck under them.
Actually, that isn't the actual car C&D used - I doubt they added the flares on theirs for the test. I thought this might stir things up a bit. :) I agree: it's not the extra length itself, but what they did with the extra length. They could have produced the same shape in the same overall length if they really wanted to (ie. designed in from the start, not as a bolt-on addition). |
MetroMPG -
That's very cool. I keep thinking that the nose is less important than the rear of the car, but a 5+% improvement is nothing to laugh at. The "look" reminds me of the original Miami Vice car, the Ferrari Daytona. CarloSW2 |
Keep in mind, it's not just the nose. They reduced the grille opening, covered the headlight buckets and cleaned up the brutal leading edge of the hood. Also probably lowered the stagnation point.
It's easy to get a 5.5% improvement when your starting point is a face like that! And, yeah, I thought it looked like that Ferarri too. Ferris Bueller's. :) |
OHHHHH YEAAAHHHH!!!
http://i146.photobucket.com/albums/r...r/ferrari3.jpg I'd wager that even as a bolt-on piece, the drag reduction could have been accomplished with much less added length. |
Ha ha, play that 33 rpm song at 45 (if you have it on vinyl)!
http://www.last.fm/listen/artist/Yello/similarartists |
This reminds me of the Stiletto kit for the Ford Pinto. I can't seem to get the pics of it to load on google images.
That '74 with the extended nose would make a sweet EV.
