Old 11-06-2009, 03:13 PM   #1 (permalink)
Exclamation 97 Chrysler LHS (OBDII trouble code)
I put my scanner on my car and the trouble code is P0401 which means exhaust gas recirculation, insufficient flow detected. What does that mean and how can i fix it???????
Old 11-06-2009, 04:46 PM   #2 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I would say the EGR passage is getting clogged or the EGR valve is clogged or shot.
If it were a Chevy V8 I would tell you to pull off the throttle body & the EGR valve. Then clean out the port going into the manifold from the EGR valve.
I would pull the EGR valve & try to clean off the build up as best I can and get as much build up out as possible. You may want to have a shop vac right by the port so the build up comes out instead of going into the manifold.
Don
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
