EcoModder.com
-   Saving@Home (https://ecomodder.com/forum/saving-home.html)
-   -   Rocket Stove: Renewable Cooking (https://ecomodder.com/forum/showthread.php/rocket-stove-renewable-cooking-13952.html)
bennelson 07-21-2010 11:57 PM
Want to be more eco-friendly at home?
How about replacing an LP grill with a homebuilt stove that runs on sticks or woodchips!?
I am building a rocketstove. You can read all about it on EcoRenovator but here is a photo to tease you with!
http://gallery.me.com/benhdvideoguy/...12797674340001
The stove in the photo is one built by a friend which I am modeling mine after.
Jyden 07-22-2010 03:33 AM
You will bee amazed about how effective it is.
Last year I build a Rocket furnace to heat my basement in winter. Cost next to nothing, use only little amount of wood, and turn out at lot of heat. Very effective!
Phantom 07-22-2010 11:34 AM
My father-in-law built one in his house the fire is in the breeze way and runs through the wall to a second chamber for a secondary burn. After that the heat is pushed through a mud/adobe couch to hold the heat and warm the house.
Here is the link to his rocket couch Rocket Stove | Northern Kentucky Landscaping from The Good Earth, Inc.
bennelson 07-25-2010 09:18 PM
More work on the rocket stove.
I assembled and welded the main components.
http://gallery.me.com/benhdvideoguy/...12801044700001
See more photos at:
MobileMe Gallery
You know what's fun?! Cooking dinner without petroleum!
http://gallery.me.com/benhdvideoguy/...12801044840001
MobileMe Gallery
Read more over at EcoRenovator
Phantom 07-26-2010 01:15 PM
I need to learn how to weld and start doing some projects like this.
bennelson 07-26-2010 01:34 PM
Yep, me too.
Seems like welding is one of those things that mostly just takes some practice. This project is pretty straight forward, so I thought it would be good for some welding experience. The welding isn't perfect, but I did it all myself! :thumbup:
Daox 07-26-2010 01:40 PM
Yeah, thats mostly what it comes down to, practice practice practice.
Phantom 07-26-2010 02:24 PM
What type of weld did you do on the rocket stove?
bennelson 07-26-2010 05:32 PM
The base, feeder tube, chimney tube, and upper tub/grill are all separate pieces.
The first day I worked on the stove, I cut all the pieces to size and to fit each other. Here's what I had at the end of work day one (a couple hours of an afternoon)
http://gallery.me.com/benhdvideoguy/...12797674620001
The second work session, I did all the welding to put those pieces together.
The welder itself was a wire-feed welder (without gas).
brucey 07-26-2010 05:48 PM
Wow, that's kinda cool. I'm going to have to look around and copy you. I have a propane grill which I regularly use in summer, about 2 tanks a summer since we cook out so much.
And those are pretty good weld for gas-less flux core on your first time too!
