Old 09-23-2010, 10:48 AM   #1 (permalink)
Want2BAHyperMiler
KCF3712's Avatar
PeytonsLimmo - '07 Kia Spectra EX
90 day: 40.55 mpg (US)
PeytonsVolMobile - '07 Chevy HHR LT1
Eoc w/ automatic
How does EOC effect / harm an automatic transmission? If got a few good places to EOC where I live, but am worried about what it is doing to my tranny.
Thanks
KCF3712
Old 09-23-2010, 11:09 AM   #2 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
My understanding is that the transmission fluid is kept circulating by the turning of the engine. So EOC-ing could potentially cause the gears to turn without a flow of transmission fluid (i.e. lubricant). This is depending how your car is set up.
Old 09-23-2010, 11:17 AM   #3 (permalink)
cmj
Honda - '96 Honda Civic EX
90 day: 36.12 mpg (US)
Why not just drop the car into neutral and coast for a while? I saw some good gains doing just that.
Old 09-23-2010, 11:18 AM   #4 (permalink)
Most conventional transmission have oil pump driven off inputshaft which spins with torque converter/flywheel.
So if engine is off then no oil pressure but for real short periods it might be ok, but I wouldn't risk it personally .
Edit: to be more specific the pump is driven from converter housing which is same as flywheel/crank, so even before inputshaft/torque converter output
The problem with neutral is the injectors are still firing where if you just left in gear (D) and let off gas injectors shut down on modern engine management systems until you hit idle speed .
The Following User Says Thank You to EdKiefer For This Useful Post:
2003protege (09-23-2010)
Old 09-23-2010, 11:40 AM   #5 (permalink)
^this
Old 09-23-2010, 12:24 PM   #6 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I agree with what everyone said above.
I saw an ad in an RV magazine for an auxillary trans fluid pump to fit onto a vehicle being flat towed. In theory, if you can get the pump to turn on when you shut the motor off, you should be ok. I don't think I'm going to try it though.
Don
Old 09-23-2010, 03:09 PM   #7 (permalink)
Want2BAHyperMiler
KCF3712's Avatar
b
Old 09-23-2010, 04:29 PM   #8 (permalink)
Originally Posted by KCF3712 View Post
b
Old 09-23-2010, 04:44 PM   #9 (permalink)
Check your owner's manual. If it says that the car can be "flat-towed" (towed with all four wheels on the ground), then it is fine to EOC with it. If it says that you cannot, then leave the engine on, and coast in neutral.
DFCO results in more drag than shifting to N. So if you don't want to slow down, say you're doing pulse & glide, you would shift to N. If you were slowing down anyway (e.g., coming up to a red light) you might leave it in D to get some DFCO deceleration.
-soD
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Quick Test: P&G with EOC vs w/o EOC shows 24% gain Daox Hypermiling / EcoDriver's Ed 16 10-08-2010 12:16 AM
Need AT EOC compatible list Sticky I will start rmay635703 EcoModding Central 3 11-20-2009 11:03 AM
Perfecting Going EOC After Dark Jammer Hypermiling / EcoDriver's Ed 20 09-30-2009 08:27 PM
Pulse and glide with Caravan automatic (actually EOC) popimp Hypermiling / EcoDriver's Ed 20 12-29-2007 01:10 AM
